Old 06-10-2007, 10:40 PM   #1
sweet72_chevy
Correct Spark Plug Gap
I have a 72 chevy c-10 with a 427 ci engine from a 69 impala i was wonderering if anyone possibly knows the correct gap to use on the plugs.
thanks for any help,
George
sweet72_chevy is offline   Reply With Quote
Old 06-11-2007, 12:49 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Correct Spark Plug Gap
If you're still using the points setup .035 ...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-11-2007, 12:54 AM   #3
dubs68SWB
dubs68SWB's Avatar
It really depends on your ignition system. Points are around .035 and HEI is around .045. If you are running something like a multiple spark discharger....like MSD, it can be .050 to .060 and higher. A lot of it, with MSD, depends on your compression ratio. Hope this helps!!
'68 Chevy SWB with 460 BBC
Muncie M-22 and Eaton posi rear w/ 3.73's
Corvette rallys with mini derby
caps
Sick horsepower and torque
dubs68SWB is offline   Reply With Quote
Old 06-11-2007, 08:28 AM   #4
sweet72_chevy
alright i will probly go with somthin around .050 then b/c i have a msd distributor and coil.
rhanks for your help
george
Old 06-11-2007, 10:11 AM   #5
dubs68SWB
dubs68SWB's Avatar
That gap is only for the MDS multiple spark discharger!!! If you are just running the distributor and not the box, like a 6AL, that might be too much gap and it will make your ignition system work too hard. You really need to check with MSD to see what they recommend.
caps
