![]() Join Date: Nov 2006
turn signal problems
ok i,ve got a problem with my turn signals and front marker light-bumper park light. heres the symptoms, when park-headlights are off i have good working turn signals all around but when i turn on my park lights or head lights i dont have any left front fender marker-turn signal or no front bumper turnsignal and the left rear wont blink also. plus when park lights or headlights are on my left turn signal light on my dash board is on bright but dont blink. right side works perfect if lights are on or off. any tips to trouble shoot this circuit. could a bad headlight switch make this happen ?
bob |
Re: turn signal problems
One of the lights has no ground or there is a wrong bulb in one of the sockets. Check all bulbs 1st. (# 1157) (side marker-push in type). To check for ground use a jumper wire with clips to check each fixture.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Check Em Tomarrow. Thanks A Bunch.
If I Dont Have A Ground Where Does The Factory Harness Groung At For The 2 D/side Front Marker Lights ?
Long Fleet Club
It is usually grounded to the housing then the body. Remove them and clean everything behind them where they mount and that should fix the problem.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
