Old 06-11-2007, 03:07 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Anybody know about...
These valves
I picked some up at a salvage yard & was wondering if they are a good valve to run & will these valves do FBSS or just FB
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 06-11-2007, 10:56 AM   #2
jimmydean
jimmydean's Avatar
Re: Anybody know about...
Looks like 8 valves to me. So depending on how you wire up switches, you could do:
Front
Back
Side
Corners
All up/down
Not sure who makes it, but looks like a good design. If they used solid valves, that could be an awesome setup.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-11-2007, 11:41 AM   #3
Shane
Shane's Avatar
Just so ya know, something very similar sold by AIM ....
AIM valves
Shane is offline   Reply With Quote
Old 06-11-2007, 12:02 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I know a lot of peeps are down on Aim, but are those valves ok ???
I know some about bag'n, but what is the difference between these being 3-position vavles Vs. ??? valves
Also, mine don't have the manifold on he bottom where can I get one ?
Oh, one more thing
My tank has a very very small "crease" in it all the way around, it's right next to the weld is this factory or is my tank gonna blow
Pics
Thanks, Matt
Sinister
Killer
Old 06-11-2007, 01:46 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
I have the same vavles on my truck and have had no problems. Of course the truck just sits in my garage but I have played around with the bags/switches/valves plenty and they have worked flawlessly. At the time I bought them, it seemed like more sense to have four valves instead of eight, and they were cheaper. I'll keep using them until I have problems, if that ever happens.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-11-2007, 01:52 PM   #6
Shane
Shane's Avatar
what the hell is going on with the end of that tank? scary stuff!
p.s. Good to see ya Jay ... where ya been hidin?
Old 06-11-2007, 05:44 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
[QUOTE=Shane;2217150]what the hell is going on with the end of that tank? scary stuff![QUOTE]
I pulled this stuff out of a ricer
And he had a custom fiberglass interior, I guess the tank was molded in as well
Sinister
Killer
Old 06-11-2007, 06:33 PM   #8
Shane
Shane's Avatar
gotcha .... i thought the thing had been hot glued back together ... LMAO
Old 06-11-2007, 06:42 PM   #9
Kontrol Phreaks
Kontrol Phreaks's Avatar
Those are a similar version to a block / manifold valve. They are a decent valve and each one will do two positions ( fill and dump ) Since you have 4 of them you will be able to do FBSS with them. Just make sure to run a water seperator / filter between them and the tank. Those valves have a sliding center pin that over time can tear the O ring from debris going through the lines. This will cause the valves to leak air on the fill, or dump side.
Good luck with the project.
Clint
Kontrol Phreaks is offline   Reply With Quote
Old 06-11-2007, 06:48 PM   #10
jamis
F.A.S.T. president
jamis's Avatar
LOL
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 06-22-2007, 10:49 PM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Does anyone know if & where I can get the manifold for these valves, as I got mine without them ???
Sinister
Killer
Old 06-26-2007, 12:11 PM   #12
pharcydekm
I run a very simular valve on mine and had them on a truck in the past. They are a decent valve. The biggest issue that I have with them is you can only run 150-175 PSI with them. As far as a manifold it is not neccesary to use a manifold. I put mine as close to each bag as I could this will give you a quicker fill and dump. Also makes for a lil bit better of a ride.
pharcydekm is offline   Reply With Quote
Old 06-26-2007, 12:18 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks for the info
I know you don't have to run the manifold, I just liked how clean it made every thing look
But I didn't know that putting the valves close to the bag made a difference, now I will be thinking about this option
Sinister
Killer
