Old 06-11-2007, 06:16 AM   #1
KFreddy
Active Member
KFreddy's Avatar
Start Up Blues...
Having 600 trouble free miles since the install of the ZZ454, the last two mornings at cold start 80* turning over the engine has started with a large clank, kinda like a hammer smacking a pan. On the second try to start it does so normally. What's going on? any thoughts? Or do i just grab a bigger towel to wipe up my tears?
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 06-11-2007, 07:09 AM   #2
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: Start Up Blues...
Does it sound like its coming from the top of the motor or the bottom?
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 06-11-2007, 07:46 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
problem with the starter drive?
68C15 is offline   Reply With Quote
Old 06-11-2007, 11:01 AM   #4
wibilly
wibilly's Avatar
check to be sure your starter is tight
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-11-2007, 12:52 PM   #5
estig70
estig70's Avatar
your problem is deffinately here by the way you are describing it. Check starter drive, starter mounting bolts, flywheel / flexplate teeth etc......... Good Luck!!!!!!
Eric
estig70 is offline   Reply With Quote
Old 06-12-2007, 12:11 AM   #6
KFreddy
Active Member
KFreddy's Avatar
Sounds like it's coming form the bowls of the motor? Hoping to agree with you'all, starter issue, hopefully...
