Old 06-11-2007, 11:26 AM   #1
rophle1
rophle1's Avatar
Engine Harness
I just bought a new engine harness and can't figure out a couple of the wires. I have the pink wire to dizzy, the two for the starter, and one running towards the brake booster all figured out, but there are three more wires (can't remember all the colors, ones blue) that I don't know where they go. I can only guess that they're for the AC, but I thought it ran off another harness.
So, does anyone have a diagram for the engine harness?
Thanks.
Ronnie
1968 C10 Stepside
396 bored .030
TH400
rophle1 is offline   Reply With Quote
Old 06-11-2007, 11:59 AM   #2
Musclerodz
Re: Engine Harness
Thanks.
Ronnie
Are they the kickdown wires for the TH400? Knowing the colors will help.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 06-11-2007, 12:33 PM   #3
shifty
Questionable
shifty's Avatar
Re: Engine Harness
99% sure the blue one is the oil dummy sender. one of the others might be the water temp dummy sender.
knowing the colors of the other wires is the only way i can help other than that.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-11-2007, 01:10 PM   #4
rophle1
rophle1's Avatar
Re: Engine Harness
I'll have to look this weekend, I'm still working on the truck a couple hours drive away, so only work on the weekends. I wasn't smart enough at the time to write down the colors.
1968 C10 Stepside
396 bored .030
TH400
Old 06-11-2007, 01:54 PM   #5
cdowns
cdowns's Avatar
Re: Engine Harness
i think theres a wiring diagram in the FAQ section /you might print it out for help when you get back to workin on it
Old 06-11-2007, 02:28 PM   #6
RyanG
RyanG's Avatar
Re: Engine Harness
Here you go this should help
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
RyanG is offline   Reply With Quote
Old 06-11-2007, 04:47 PM   #7
rophle1
rophle1's Avatar
Re: Engine Harness
Thanks, that helps a lot. I have mechanical temp and oil pressure, so that answers two of the unknowns. I noticed that there wasn't a wire going to the dizzy in the diagram . This could be a stupid question (won't be my first or last), but what is the item that is labeled "backing LP.SW. Conn.? It has a black 18DG and a green 18LG running into it.
Thanks.
Ronnie
1968 C10 Stepside
396 bored .030
TH400
Old 06-11-2007, 05:16 PM   #8
RyanG
RyanG's Avatar
Re: Engine Harness
It looks like it could be the power to the main light on circuit board behind the instrument cluster. Only one of the lights has a wire going to it. The rest are in series connected by the copper wire in the circuit board or what ever it is called. I am about 85% sure, if I am wrong maybe some one else can clear it up.
Old 06-11-2007, 05:35 PM   #9
RyanG
RyanG's Avatar
Re: Engine Harness
It could also be for the Licence plate light in the back. Now I am 50% sure.....LOL
