Old 06-11-2007, 01:11 PM   #1
7791manz
Disc Brake Swap Revisited
I am a newbie to this forum and want to say that I have found alot of valuable information on this site.
I have a 69 C10 396/turbo400 from North Dakota that I am restoring.
I have searched and read all I could find on the disc brake swap and have just a few additional questions.
I have the master cylinder/vacuum booster, front spindles, rotor, calipers, proportioning valve and complete steering linkage off of an 85 C10.
From what I can tell from this site all I have to do is use the control arms that are on my 69 with ball joints for an 85 and then the spindles will be a bolt in. I can either use the complete steering linkage from the 85 or I will have to purchase a special adjuster sleeve to use the 69 centerlink and inner tie rod. The 85 master cylinder/vacuum booster will work but I have to modify the mount and the rod to the brake pedal.
Could someone please confirm that the above is correct or set me straight if it is not.
Also, what is the best way to obtain 5 lub axles for the rear? I have heard that the 6 lug can be redrilled or buy new axles or a complete rearend. Any help on the best way to proceed would be greatly appreciated. My 12 bolt appears to be in great shape.
Thanks in advance for the help!
7791manz is offline   Reply With Quote
Old 06-11-2007, 03:16 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Disc Brake Swap Revisited
I'm pretty sure you can put the ball joints for the 85 in your control arms. I just swapped out the control arms altogether when I did my swap, but I've read about other guys just swapping ball joints. You will need to use the steering components from the 85 (centerlink, tie rods, etc), except I think you'll need to keep your stock pitman arm. When I did my swap with parts from an 89 Burb I used all the Burb steering parts except for the pitman arm because it was too big to fit my 68's steering box. Not sure about the rear; that's something I'm still trying to figure out myself. I'm thinking about having my axles drilled, but I don't know how much t would cost. Hope I've helped you out some.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-11-2007, 03:25 PM   #3
PrinsGMC
PrinsGMC's Avatar
Lets see some pictures of the truck.
69 GMC lwb 1/2 Ton 396
76 Chevy k10 short step 4x4
PrinsGMC is offline   Reply With Quote
Old 06-11-2007, 05:55 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
7791manz,I suggest you check out the threads in the FAQ's section for disc brake swaps.I believe the info you were given is correct but the FAQ threads will have you overloaded with info on the swap.Knowledge is power.The easiest way to find stuff in FAQ is to use krue's index.There are probably a dozen or so references to the swap there.Much more than I could type this evening.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
