Old 09-16-2002, 12:14 PM   #1
wlee
Just an Old Mr Goodwrench
Question Question about replacing visor mounts
Has anyone here ever replaced the visor mounts on their truck? Is there a trick to remove the clip holding the spring on the visor arm? Thanks!
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 09-16-2002, 12:27 PM   #2
70c10
67-72 Addict!
70c10's Avatar
I think it is pressed on at the factory. I usually just pull the rod assembly out and replace the whole thing.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-16-2002, 12:36 PM   #3
wlee
Isn't the rod attached to the fibre board?? I tried to pull, but it didn't want to come out & I was afraid I'd tear up the visor. Will it pull out with a little force? Thanks!
1992 Mazda Miata
Old 09-16-2002, 01:51 PM   #4
JimKshortstep4x4
Smile
If you spray along the shaft so that penetrating fluid will flow inside, you can usually pull the shafts out with a back and forth twisting motion. The sleeve that the shaft holds the visor on keeps it in place by friction only, (there are no clips or retainers).
I have not had any that the shaft could not be removed after it was soaked down.
Jim
Old 09-17-2002, 10:20 AM   #5
wlee
Duh . . . I took 70c10's advise & tried pulling the rod . . . it came right out with some twisting - Thanks!
1992 Mazda Miata
Old 09-17-2002, 10:41 AM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thumbs up
I have a couple of spares you can have for the cost of shipping.
Send me you zip for cost estiment
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
