Low buck ls1 fan install
$50 ls1 fans, used
$25 aluminum angle, misc hardware Find/buy your own controller, or use relays/temp switch. ![]() ![]() ![]() ![]() ![]() Trimmed a little off the top of fan, had some "ears" that stuck out. Just got this done this evening, might have time this week to finish up the wiring and the rest of the serp conversion. Not much left.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
The One And Only !!!
Re: Low buck ls1 fan install
Looks sweet !!!, But....You shoulda known we need to know what donor you got the fans off of.
I like that set-up better than my single aftermarket.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Dark Heart Motorsports
awesomeness...!
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
01 Z28
Thanks, Are you going to run both fans constantly or wire one to come on with the AC ?
I have the flexalite vsc. It has a bunch of features. It will engage with temp control, and has a/c trigger. When it turns on the fans, it only runs them at like %50 or so, if it needs to it will run them at %100 if needed, depending on temp.
