06-11-2007, 10:05 PM | #1 |
Wild Goose Chase????
Okay, so heres the deal. i have a big block in my 70 c10 and in the truck that i swapped motors with had a double groove pulley on the p.s pump. Im using the brackets out of that truck (compressor on driver side, alt. on pass side). So im thinkin im gonna need a double groove pulley as well. The problem is that my pump has a keyed shaft so a press on pulley wont work. DO THEY MAKE A DOUBLE GROOVE P.S PULLEY THATS KEYED????
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
06-12-2007, 08:18 AM | #2 |
Re: Wild Goose Chase????
Yes they do, I think mine was off a '73 pickup with air. Should be a bunch at the junkyard.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
06-12-2007, 08:29 AM | #3 |
might be easier to just get a press on style pump.
i just installed a pump for a 78 camaro, and it cost me $40. It saved me a ton of running around, and maintains the standard threads.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
