Old 06-11-2007, 10:40 PM   #1
NICK3757
NICK3757's Avatar
s10 five speed question
Is the 5 speed trans out of a 90 2wd s10 with a four cylinder strong enough to take a stock 307? And is it the same as one out of a v6 truck?
NICK3757 is offline   Reply With Quote
Old 06-11-2007, 10:51 PM   #2
retselgerg
retselgerg's Avatar
Re: s10 five speed question
Believe they are different not sure tho,
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 06-11-2007, 11:44 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
same tranny, but the 4 cylinder one is even more lame than the V6 one.
A stock 307, if you drive it like an adult... no tire spinning and minimal towing... you should be OK.... or, ok-ish at least.
Old 06-12-2007, 12:11 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
You'll need to trim the bearing retainer a bit and trim the end off the input shaft about 1/4"-3/8" in order for it to bolt up. If you encounter resistance when bolting it on, you'll need to find out why. Also, be aware that the 89 and above and maybe a bit earlier all have electronic speedo output.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 06-12-2007, 12:45 PM   #5
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
The 4 cyl S10's were equipped with a T-5, standard issue tranny, I think they're rated to about 180 hp.
The V6 trucks did not actually have a T-5, they were equipped with a Muncie tranny which is much more stout (it also has a single piece case w/ integral bell housing).
The later v6 trucks have (98 and newer) had the strongest 5 speed, and probably the only one that will stand up to any kind of abuse behind a V8 ( it's an NV3500 if memory serves)
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 06-12-2007, 01:37 PM   #6
3/4tonterror
3/4tonterror's Avatar
i dont know about the s-10 t-5, but i took a t-5 from a 89 firebird and have it behind my 454 bb, in my mustang gt. it works fine but be carefull if you want to beat on it.it held together for about 4 yrs now.
3/4tonterror is offline   Reply With Quote
Old 06-12-2007, 04:57 PM   #7
JJorgensen52
The camaro and firebird boxes are much stouter than the S10 ones. They are world class (otherwise known as T-5Z) and rated to handle 360hp, or some of the later ones to 390hp. I'm running the same T-5 from an 89 IROC in my Sonoma.
That said, the F-body box will not work in a 4wd without a lot of case mods
Also missed earlier, the electronic speedos are kind of a mixed bag. The firebirds got electric in 87, and the camaros in 91. Anything up to the 91 has a gear driven electronic speedo and can be swapped out for a cable drive in about 5 minutes.
CURRENT
SOLD
Old 06-12-2007, 05:47 PM   #8
Longhorn Man
the world class goes by year... old F bodys had the weak kneed model, later got world class... which even the WC one is only rated at 305 ft pounds of torque.
Old 06-12-2007, 10:57 PM   #9
NICK3757
NICK3757's Avatar
Thanks for the info. I have to go to the local junkyard and se if i can find a camaro box.
Old 06-12-2007, 11:30 PM   #10
Longhorn Man
camaro one will need a wedge adapter fabbed for the mount... it mounts at an angle on te camaro, and the shifter will be under the bench seat
Old 06-13-2007, 12:09 AM   #11
NICK3757
NICK3757's Avatar
Yea. I know about the whole camaro trans problem. We had a 68 camaro come in that was totally butchered and thrown together with leftover parts. They never modified anything so the trens will sit level so the shifter was hitting your leg ant there was no feathering the clutch. it was in or out.
Old 06-13-2007, 09:16 AM   #12
grayw0lf
I've pulled more than one T5 from V6 88-91 S-10's. Some with the 2.8 & some with the 4.3L.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-13-2007, 12:52 PM   #13
JJorgensen52
My bad, I meant the 4.3 v6 trucks.
I have all the dimensions needed to build a wedge tranny adapter if anyone is interested, shoot me a PM
CURRENT
SOLD
