06-12-2007, 12:20 AM | #1 |
Project SlammedC10 -Back From The Dead
I finally got back to work on my truck again after almost 2 years. I got the truck when 14 and worked on it for 2 years off and on until i moved away. It sat in storage until recently. In the last week i have started bagging it. Let me know what you think.
06-12-2007, 12:32 AM | #2 |
Re: Project SlammedC10 -Back From The Dead
i still have to box the frame around the notch and finish welding a couple things
06-12-2007, 01:16 AM | #3 |
looks pretty good, anymore pics of the whole truck? other specs on it?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-12-2007, 01:47 AM | #4 |
Its got a 350 w/ a 700r4 that i put in when i started the project. But I am seriously considering a gen III 6.0 w/ a 6 speed. Ive got the hook up for parts cause i work at the salvage yard so it will hopefully happen. Every things new except the chassis and cab. 2600 firestone bags, a big compressor and heavy duty industrial valves. It almost lays the cross members as is. It scrapes lightly on the floor in the shop. I plan on sectioning the crossmembers [trailing arm and front], using drop spindles, and modifying my lower control arms by plating the bottoms as i saw somewhere here.
I'll get more pics tommorrow. Last edited by slammedc10; 06-12-2007 at 01:52 AM. |
06-12-2007, 06:33 AM | #5 |
Welcome from NW FL! Cool project.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-12-2007, 10:06 AM | #6 |
Post Whore
Welcome to the board!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-12-2007, 10:16 AM | #7 |
Tightwad
Welcome back can't wait to see some more pics of the project....
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
06-12-2007, 10:21 AM | #8 |
welcome back!
looks like a good start although i'd fish plate those notch welds and cut that box tubing out and put some 1 1/2" dom in there just for the appearence factor.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
