Old 06-12-2007, 08:24 AM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
I want to make a dually out of a long bed.
I need to know from what vehicle I can rob the dually rear end out of that will work under a stock long bed 67-72. I believe it needs to be narrower than a stock dually...like a gruman van or something.
Does anyone have any info on this??????????
72freak is offline   Reply With Quote
Old 06-12-2007, 08:33 AM   #2
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: I want to make a dually out of a long bed.
You can use the dually rear end from a 67-72, which I call cab & chassis width. Your outer tires on the duals will stick out very slightly, and your inner duals will be tucked in.
Cab/chassis trucks from 67 up to 91 (old body 73-87 style) will have rear ends that will work as far as leaf spring spacing.
You will have to modify your inner wheel tubs in the bed to run a cab/chassis dually rear. One drawback to this is that you no longer have 4 feet between the tubs; something to think about if hauling sheet goods.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 06-12-2007, 08:51 AM   #3
1lowdiesel
1lowdiesel's Avatar
you could something like this, he used stepside fenders and extended them down.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-12-2007, 10:07 AM   #4
72freak
72freak's Avatar
I have a set of step side fenders in inventory for that very reason!!!!!
I like it!!!!!
Old 06-12-2007, 05:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that's my plan too, but I want to cut it so it is narrower in front.
Old 06-12-2007, 06:09 PM   #6
Rokcrln
Rokcrln's Avatar
That is a cool truck but it needs two more doors to be just right!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-12-2007, 06:29 PM   #7
BCOWANWHEELS
i,ve got a factory dual wheel rear end, 4.10 ratio, ho 72 eaton. 300.00
bob in tn.
BCOWANWHEELS is offline   Reply With Quote
Old 06-12-2007, 06:50 PM   #8
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Heres a few pics of my bed, the 14 bolt rear I am using is a standard 1 ton rear so its a little wider than a cab and chassis rear. Mine uses the stepside fenders and has been tubbed, I'm in the process of changing to the larger 3 1/2" brake shoes for much better stopping power.
I may also switch to cab & chasiss hubs to tuck the tires in 2" more but I'll have to wait and see how the tires fit when its back together.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-12-2007, 07:23 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I like it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-12-2007, 10:47 PM   #10
Chris H
Chris H's Avatar
Rob,
I would love to see a profile shot of the side of your bed, just want to get an idea of how wide your step-dually-side fenders look from the rear.
Is this the one that is getting the new wheels??? That is going to look great!
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 06-12-2007, 10:52 PM   #11
GREASEMONKEY72
GREASEMONKEY72's Avatar
i love duallies
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-13-2007, 12:02 AM   #12
BLAZERMAN
BLAZERMAN's Avatar
Chris, Yes this is the truck that the 19.5s are going on.
The fenders dont stick out as far as some I've seen, just enough to clear the tires.
Old 06-13-2007, 09:39 AM   #13
1lowdiesel
1lowdiesel's Avatar
that's sweet very clean.
what wheels you goin with?
xtremediesel.com
Old 06-13-2007, 07:04 PM   #14
BLAZERMAN
BLAZERMAN's Avatar
The wheels are American Alloys in 19.5 x 6 and the tires are Cooper 8R C-140s
Old 06-13-2007, 07:09 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Old 06-14-2007, 12:22 AM   #16
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
The best C10 Dually ever thanks to GRANT
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
