Old 04-28-2002, 02:22 PM   #1
chevy71super
Post Left Front Brake Dragging
My left front disk brake is dragging on my 1971 K10. Does anyone know what the cause generally is? It gets so hot it smokes. I replaced the right front a couple of years ago and I will probably just go get a rebuilt one for the left. Thanks
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 04-28-2002, 03:55 PM   #2
3truckcanuck
Post
More than likely the piston in the left front caliper is seized and will not return to its proper position when the brake pedal is released...
3truckcanuck is offline   Reply With Quote
Old 04-28-2002, 08:38 PM   #3
RainDog
RainDog's Avatar
Post
99.9% of the time that's the piston in the caliper, like he said. Usually the easiest fix is just slap a new caliper on there.
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats."
RainDog is offline   Reply With Quote
Old 04-28-2002, 09:26 PM   #4
snow man
Smile
sent you mail snowman
snow man is offline   Reply With Quote
Old 04-28-2002, 11:06 PM   #5
chevy71super
Post
Thanks Snowman & everyone else. I went to Schuck's and bought a rebuilt one. (I wish NAPA was open on Sunday.) The price was right, 20 bucks after I gave them my core. Snowman suggested the brake lines probably need replacing. That's what I will do next. Not a good idea to have all new brakes with 30 year old rubber lines.
72 Cheyenne 4X4 SB
Old 04-29-2002, 03:46 AM   #6
WORNBRAKES
Post
My '68 does the same thing but usually after sitting for a while. The rear brakes also lock up at the same time. I am going to repack the wheel cylinders. The rear one is leaking. I hope it fixes the problem. I will let you know.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 04-29-2002, 08:39 AM   #7
Blazer1970
Blazer1970's Avatar
Post
It could easily be the hose also. The old rubber lines swell shut on the inside so that the fluid will be forced through when you step on the pedal, but there is no spring or anything on the piston in the caliper to force it back through. Disk brakes depend on the free flow of fluid back to the reservoir to release the pads. I have seen this happen on rubber lines that were only a few years old. This is probably the same thing snowman said. Snowman please post your advice on the board for everyone to see!
[This message has been edited by Blazer1970 (edited April 29, 2002).]
Blazer1970 is offline   Reply With Quote
Old 04-29-2002, 10:10 AM   #8
BigDave
I poop on Ford!
BigDave's Avatar
Post
I had the same problem a few months ago. One morning, I noticed from a stop the truck would pull to the right a little. By the time I got home that afternoon it was pulling hard to the left under braking and still pulling to the right from a stop.
I pulled the wheels and inspected both hoses and the calipers. I tried to bleed the right side and sure enough I was just getting drips through the line.
Since both hoses appeared to be about the same age I replaced them both and solved the problem.
1972 Chevy Blazer 2WD - 400 SBC, bored, ported/polished heads, 9.5:1 dished pistons, Lunati 480/292 cam, electronic ignition, Edlebrock Performer intake, tricked out Rochester 850CFM Quadrajet, long tube headers, Flowmaster 40's, TH350-C with lock-up switch, 2800 rpm stall, shift kit, custom driveshaft, stock GM 12- bolt rear with Auburn Pro Series limited slip 3.73's, 2" drop spindles, 2" drop rear coils, track bar kit, front/rear stabilizers.
1999 30th Anniversary Trans-Am Coupe #1494 - M6, Flow-tech cut-out, Flowmaster, free mods. One of 292 coupes with M6 and in-dash CD.
1972 Chevy Cheyenne - LWB, factory 402BB
2005 Chevy Suburban LT
2006 Chrysler 300C - SRT8
BigDave is offline   Reply With Quote
Old 04-29-2002, 10:18 AM   #9
snow man
Smile
the reason i did not post for every one to read was my reply would not work on the board. its is working now so i will help out when i can. thanks guys the snowman in ill.
