Old 06-12-2007, 10:00 AM   #1
casterbuster
Mejor Que Nada
casterbuster's Avatar
Problems after power disc brake conversion ??'s
i recently completed my ece power disc brake conversion. In doing so I replaced all of my brake lines as well. I also replaced my rear emergency cables.
I got this all finished up Sunday morning, everything was working great.
I had to leave the truck at my dads, I live 3 hrs away. He called me last night he said he had been using the truck to move some stuff around in the yard. He then said he was doing quite a bit of backing up. Now, he says the rear drum brakes are locking up. He said that he can loosen the line fitting on the proportional valve to bleed off pressure and the brakes will release, but will start to lock up again shortly afterward.
Do you guys have any clue what might cause this?
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 06-12-2007, 02:19 PM   #2
casterbuster
Mejor Que Nada
Re: Problems after power disc brake conversion ??'s
ttt
Old 06-12-2007, 02:21 PM   #3
rlm316
rlm316's Avatar
When you had the rear brakes apart did you check the condition of the self adjusters? It sounds like the rears are over adjusted. You will need to pull the rear drums and check the adjusters. When you apply the brakes in reverse the brakes adjust themselves by a lever attached to the primary shoe which when the brakes are applied, turns the adjuster wheel. Also there is a residual pressure on drum brakes if I'm not mistaken.
rlm316 is offline   Reply With Quote
Old 06-12-2007, 02:27 PM   #4
estig70
estig70's Avatar
yeah what he said.
take the drums off, and readjust to where you have slight drag.
Eric
estig70 is offline   Reply With Quote
Old 07-17-2007, 02:32 PM   #5
casterbuster
Mejor Que Nada
Finally found the Problem, all I can say is duh. The brake pedal rod was adjusted out to far loosened rod, wah lah brakes released
Old 07-17-2007, 02:35 PM   #6
krue
Designated A-hole!
krue's Avatar
Beat me to it, I had that problem with mine.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-17-2007, 02:36 PM   #7
jkaylor68gmc
jkaylor68gmc's Avatar
That will do it.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
