Old 06-12-2007, 10:10 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Need more gas??
I installed my refurb stock tank back in the truck. After instaling the tank I added about 1/2 gallon of gas and drove around the block. Coming back up the hill it died. I figured there was not enough gas in the tank for it to pick up. Got 2 more gallons added to the tank and took off for another spin. When I went down a hill the coming up the other side it died again. I got it back to the house and since the battery was dead I left it alone for the night. Do you think there is still not sufficent gas in the tank for it to go down and back up a fairly steep hill? Please also take note that this truck had been sitting for 15 years. I did change the fuel filter and all rubber fuel lines as well.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 06-12-2007, 10:18 AM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Need more gas??
Almost sounds like somethings wrong with the float level in your carb....
Did you put a new carb on or reusing the carb that has been on there? If it is new, reset the float, if it is old, you may need to clean it or rebuild it...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-12-2007, 11:55 AM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Need more gas??
Any ideas guys and gals?
Old 06-12-2007, 12:17 PM   #4
cdowns
cdowns's Avatar
Re: Need more gas??
take out a bank loan and buy 5gallons
Old 06-12-2007, 12:22 PM   #5
hyarbour
Re: Need more gas??
I agree with John Fabris, sounds like a float problem. Even a rebuilt carb can have a float hang up.
hyarbour is offline   Reply With Quote
Old 06-12-2007, 12:24 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Need more gas??
Was the fuel filter really dirty? The carb's filter could be plugged some too.
Try more gas first and see what that does, these tanks have a fairly large bottom and the siphon doesn't really sit right on the bottom.
If that doesn't work, you may need to buy a vented gas cap.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-12-2007, 12:25 PM   #7
Green Machine
Green Machine's Avatar
Re: Need more gas??
The tank on our 1970 has 4 gallons left after the gauge hits empty, get the loan and try more gas first, thats the easiest.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-12-2007, 02:06 PM   #8
cstanley
cstanley's Avatar
Re: Need more gas??
check that little filter on the float. mine got sucked up into the fuel sender and did the exact same thing.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 06-12-2007, 02:50 PM   #9
screamin_eagle
screamin_eagle's Avatar
Re: Need more gas??
my truck will suck the tank dry. fill it up and limp it over to your nearest parts store so you can bolt on a new edelbrock.
screamin_eagle is offline   Reply With Quote
Old 06-12-2007, 05:53 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Need more gas??
well, it's gonna need more fuel anyways, so trythat first, then there will be no doubt.
Old 06-15-2007, 01:23 PM   #11
67ChevyRedneck
Re: Need more gas??
Problem solved?
Jesse James
Project "On a Dime"
Old 06-15-2007, 01:59 PM   #12
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Need more gas??
Originally Posted by 67ChevyRedneck View Post
Problem solved?
Kind of. I put more gas and changed filter in the carb and that did not solve the problem. Gas was getting to the carb but it would not start unless I poured gas in the intake.So i sent the carb off to these guys today at lunch to be built http://www.smicarburetor.com/ on the advice of JimPA
