Old 06-12-2007, 03:14 PM   #1
CUSTOM 72
CUSTOM 72's Avatar
Install Air Ride Question ?
HEY ALL
I'M FINISHED MOUNTING THE BAGS AND WILL BE INSTALLING THE AIR SYSTEM TONIGHT. I CAN TELL YOU THAT THEY DON'T GIVE YOU VERY GOOD INSTRUCTIONS HOW TO INSTALL IF YOU ARE A FIRST TIMER . I'M RUNNING THE 2WAY BIG RED SYSTEM FROM AIR RIDE, CAN I JUST LEAVE THE EXHUST VALVES OPEN OR SHOULD I RUN A LINE FROM THEM AND DUMP THE AIR ELSWERE?
IS ANY BODY HAVING ANY PROBLEMS WITH MOUNTING THE COMPRESSOR, TANK AND VALVES UNDER THE BOX -- WITH DIRT WATER ?
ANY PHOTOS OF THE WIREING AND AIR SETUPS WOULD BE GREAT.
I WILL POST SOME PICKS WHEN IT IS COMPLETE.
THANKS TO ALL THAT ANSWER.
1972 c/10 Custom, Long Box, 350 Small Block, Auto 3 Speed, Custom Wood box, Full Air Ride, 3" C-Notch, 20" Front & 22" Rear Tires, Snow White Paint, PT Crusher Handles,
CUSTOM 72 is offline   Reply With Quote
Old 06-12-2007, 04:08 PM   #2
1lowdiesel
1lowdiesel's Avatar
Re: Install Air Ride Question ?
you can just leave the valves open. i'd also mount the comp on some rubber pads to cut down on vibration. also the comp would be fine to mount under the bed along w/ everything else. this way if you have to take the bed off you don't have to mess with a bunch of wires. also i'd mount the pressure switch on the same side as the comp, this was you have less wires.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-12-2007, 04:23 PM   #3
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
hope these help
[img]http://www.*****************/how_to/wire-diagrams/8valve.gif[/img]
'85 swb
droppedgmc is offline   Reply With Quote
Old 06-12-2007, 04:38 PM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
here we go, after some digging
'85 swb
Old 06-12-2007, 08:10 PM   #5
pissonNOS
senior member
pissonNOS's Avatar
wow that looks confusing makes me think i did something wrong
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-13-2007, 10:15 AM   #6
CUSTOM 72
CUSTOM 72's Avatar
Thanks For All The Replies -- I Got It Done Lastnight. I'm Like A Kid In A Candy Store. This System Works Very Nice ( Quick ).
Old 06-13-2007, 10:23 AM   #7
1lowdiesel
1lowdiesel's Avatar
pics!!!
xtremediesel.com
Old 06-13-2007, 11:43 AM   #8
CUSTOM 72
CUSTOM 72's Avatar
I Will Try And Get Some Pics Soon As It Is Going In To A Car Show On Sunday, Still In Primer But It Looks Killer. I Have A Lot Of Little Things To Get Done Before I Put It On The Road.
