Old 06-12-2007, 03:41 PM   #1
jkade
jkade's Avatar
Will a 73-87 front crossmember use components for a 72??
I may have found a deal on some tubular lower control arms and a 73-87 crossmember that a guy bought with a project truck and he isn't going to use any of it. The crossmember has been cut and set up for a rack and the tubular lower arms are new with balljoints and are for a 87 down. Will my spindles work with this and I would buy some tubular uppers also.
jkade is offline   Reply With Quote
Old 06-13-2007, 10:15 AM   #3
Shane
Shane's Avatar
Re: Will a 73-87 front crossmember use components for a 72??
your links don't work bro ... they take you to the Photobucket main/home page
Shane is offline   Reply With Quote
Old 06-13-2007, 10:50 AM   #4
jkade
jkade's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=245183
They are working in that thread
Old 06-13-2007, 11:53 AM   #5
Shane
Shane's Avatar
weird ... they work in the other post, but not this one ....
Old 06-13-2007, 12:26 PM   #6
bigblock73
yeller
bigblock73's Avatar
They don't work in this thread because jkade highlighted, copied & pasted the links from the other thread (where they were posted correctly). Do a right click properties on these links, you'll see the "..." messing things up.
try these
http://i20.photobucket.com/albums/b2...sc/misc049.jpg
http://i20.photobucket.com/albums/b2...sc/misc050.jpg
http://i20.photobucket.com/albums/b2...sc/misc051.jpg
http://i20.photobucket.com/albums/b2...sc/misc052.jpg
http://i20.photobucket.com/albums/b2...sc/misc048.jpg
http://i20.photobucket.com/albums/b2...sc/misc047.jpg
http://i20.photobucket.com/albums/b2...sc/misc046.jpg
bigblock73 is offline   Reply With Quote
Old 06-13-2007, 12:40 PM   #7
jkade
jkade's Avatar
Originally Posted by bigblock73 View Post
How you know that is what I did
Old 06-13-2007, 12:54 PM   #8
bigblock73
yeller
bigblock73's Avatar
Cause I have done it myself before.
That is basically the only way to do what you did...unless you manually typed in the hyperlinks with the ... intentionally.
Old 06-13-2007, 01:11 PM   #9
jkade
jkade's Avatar
You are right
Old 06-13-2007, 02:56 PM   #10
fastbagged68
fastbagged68's Avatar
Hey I little insite on that crossmember and arms....It is a Bill Turner peice. I have the same on on my suburban. That is a pretty good deal for the parts. You should weld the Control Arm mount into the crossmember. Attached is a pic of a truck we did with those control arms. no dropped member. My suburban has a both!!!! I would make your own upper arms. If you don't want the crossmember let me know how I could get ahold of it!!!
If you want to use it you will need to switch out your ball joints to the correct ones to fit your spindles.
fastbagged68 is offline   Reply With Quote
Old 06-13-2007, 07:56 PM   #11
jkade
jkade's Avatar
So Bill did the cutting and the muskratII job as well to the crossmember or did he offer that? I just hate to buy it and it be a 1/2 ass job. If it will work I will buy it.
Old 06-14-2007, 02:18 PM   #12
fastbagged68
Bill would do them for guys. He did not do mine. I did mine myself. If Bill did it, most people didn't get them for months!!!! Who ever owns this crossmember might be able to tell you.
Old 06-14-2007, 03:09 PM   #13
jkade
jkade's Avatar
It came with a project truck he bought, so he has no idea.
Old 06-14-2007, 03:51 PM   #14
fastbagged68
If you want to lay frame that crossmember will do it. You will need to do some cutting though to make it work. You will have to cut down the rack width, cut down your tie rod ends, make an adapter to go from the rack to your tie rods, you will have to make motor mounts to make it sit right, cut the tranny tunnel, if you don't have a high hump, you will have to cut the frame to make the steering cross through it. You should make a set of upper control arms.
I'm not sure how big of a tire you want to run in the front, but with that lower arm I don't really think you can drive ultra low. I think I am going to narrow mine so I can drive it low and steer.
Old 06-14-2007, 03:55 PM   #15
fastbagged68
Oh ya on more thing.....In order to lay out you need the cut the bottom off the crossmember so that it is level with the control arm mounts. It will allow you to lay the frame rails on the ground @ the same time you lay the crossmember.
