06-12-2007, 08:59 PM | #1 |
Will this work???
I may have found a deal on some tubular lower control arms and a 73-87 crossmember that a guy bought with a project truck and he isn't going to use any of it. The crossmember has been cut and set up for a rack and the tubular lower arms are new with balljoints and are for a 87 down. Will my spindles work with this? I would buy some tubular uppers also to match the lowers, so would I buy for 72 or 87 down?
06-12-2007, 09:04 PM | #2 |
Re: Will this work???
i dont think the spindles fit the 73+ a-arms but i could be wrong
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-12-2007, 09:07 PM | #3 |
06-12-2007, 11:15 PM | #4 |
Spindles will interchange if the correct year ball joints are used (73-87 spindles need 73-87 BJ's; 71-72 spindles need 71-72 stuff etc...).
Again.... same for the upper tubular arm question. Just get the right BJ for your spindle & it will bolt in to a later style a-arm. I used 73-up disc brake spindles on my 68 lower a-arms using the later BJ.s. I used the 68 upper a-arms w/the later BJ's. I connected the steering arms to the tie-rods w/a 72 center-link on one truck & on my other one I just went ahead & used all 73-up steering gear cause the 73-up center-link was easier to find @ a wrecking yard.
06-12-2007, 11:18 PM | #5 |
well that answers it for both of us^
06-12-2007, 11:46 PM | #6 | |
06-13-2007, 08:58 AM | #7 |
http://i20.photobucket.com/albums/b2...sc/misc053.jpg
http://i20.photobucket.com/albums/b2...sc/misc049.jpg http://i20.photobucket.com/albums/b2...sc/misc050.jpg http://i20.photobucket.com/albums/b2...sc/misc051.jpg http://i20.photobucket.com/albums/b2...sc/misc052.jpg http://i20.photobucket.com/albums/b2...sc/misc048.jpg http://i20.photobucket.com/albums/b2...sc/misc047.jpg http://i20.photobucket.com/albums/b2...sc/misc046.jpg Does it look like it is worth messing with??? It hasn't been cut the way you all do it has it?? |
06-13-2007, 09:02 AM | #8 |
Without knowing if a 'qualified' person did the welding..... it's hard to say. It does look kind of rusty & that would be a concern for me.
What parts complete this 'kit'? What R&P does it use?
06-13-2007, 09:07 AM | #9 |
A guy with a truck
With it being cut that way, you will have to fab engine mounts.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-13-2007, 09:18 AM | #10 | ||
Gringo, that is what I figured since it is cut that way, I guess I could buy some of them universal mounts for a ls1 and cut them down. He wants $225 for the cross and $175 for the tubular lowers. |
06-13-2007, 10:20 AM | #11 |
Cereal Killer
Jkade...if you dont use the tube lower arms will you let me know if there still available. Do you know what brand they are?
Thanks Mark
If I dont do it....somebody else will. |
06-13-2007, 10:44 AM | #12 |
This is the lower contol arms. |
06-13-2007, 10:45 AM | #13 |
06-13-2007, 10:59 AM | #14 |
Cereal Killer
Is the balljoint replaceable? Never seen a set like those.
06-13-2007, 02:59 PM | #15 |
Those are Bill Turners Arms... they look a little different then mine though. If you want more pics of those crossmembers and control arms do a search in the suspension forum for Crossmember drop....It is probably the longest thread of all time!!!
06-13-2007, 03:47 PM | #16 |
Reckon bill did the cross member also???
