Before and After
Will a 67 hood fit n a 72 front end or would I have to change the fenders as well?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
you will also need the fenders to have it fit right.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
We presently have 68 fenders with 70 hood and a 70 grille. It wouldn't have worked if we new it was not suppose to but it fits unnoticable for now. The truck came in (new) pieces that we fit together till we got to the Brothers chevy truck show and found we had the wrong combonation of parts. When my boy gets some money he may go with the 67 hood and grille. Good luck Ed ke6bnl
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
So Many Ideas, So Little Money
any hood will go on any year fenders if you have the right latch, the 67-68 hood will go on a 69-72 fender set BUT without modification the grill won't work at all, I have a picture I'll post later
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
L.E.D. Freak
I've allways wanted to put a 67 Cowl hood, on a stock 72 front clip. How hard will this be to make it look right?
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
looks sweet, but man, it'd take work, I plan to get a 67-8 hood and try my luck and see what I can figure out sometime
As far as I know, you can do it but you need everything. You need the 67 rad support, fenders and hood to make it all work. I have been debating on whether the swap my 72 chevy front clip for a 67 GMC front clip. The parts are available to me, so it's in the works
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
chevy2racr I've been thinking of doing the same thing for awhile now. If you figure out how to do it let me know. BTW was that an actual pic of a truck with the mod or some digital magic....Stroker
72 SWB parts and pieces Oklahoma |
stroker, that is supposbly an acutal one, I bet it is, the side maker lamps are shaved too, Someone posted that a while back, I may go look for a hood this weekend infact, get sometign o play with :-D
Over worked under paid
To help out here, the 67-68 chevy fenders and the GMC's up to 72 (I believe) are the same, you need the correct grill top bar hood latch and hood to do this swap.
I tryed to put the 67 hood on my '69 GMC front clip and it sits too far forward. The hood latch doesn't line up and it hits the top bar of the grill so it won't close. To mate the hood up you need the correct fenders so the hood lines up, the thinner grill top bar 67-68 GMC and the 67-68 hood latch. Good luck!
Roger '69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears |
