Old 06-13-2007, 08:00 AM   #1
rophle1
rophle1's Avatar
Is this a good price?
I haven't bought exhaust in a long time, so tell me if this is a good deal or should I keep looking. I was quoted $371 for everything from the headers back; pipes (2-1/2" going into muffler and 3" coming out), super 40 flowmaster mufflers, 4" chrome tips, and labor.
What do you think, keep looking or go for it?
Thanks.
Ronnie
1968 C10 Stepside
396 bored .030
TH400
rophle1 is offline   Reply With Quote
Old 06-13-2007, 07:00 PM   #2
Smitty
Smitty's Avatar
Re: Is this a good price?
I did the same thing with mine. Used aluminized pipe and had it siamesed, instead of the usual H-pipe. Mine comes off stock rams horn manifolds and I also had them split and flange the pipes behind the cab so that I could drop that section if I needed to drop the trans at a later date. Also have them run the pipes toward the outside of the rails if you are even thinking about a blazer tank at a later date. That way the heat isn't so close to the tank. Out here I had a known shop that does a lot of custom work and street rods and paid dearly for his reputation. I put about $750 in it. But that .060 over 350 sounds oh so nice! I always figure that you get what you pay for. Some times the quality costs a little more the first time around than cheapin it the first time and then having to revisit the job with more money later on.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-13-2007, 07:03 PM   #3
71chevylowrider
71chevylowrider's Avatar
That sounds right in the ol ball park to me, it's gonna all be welded right? Not just bolted together.
71chevylowrider is offline   Reply With Quote
Old 06-13-2007, 08:16 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Sounds about right to me.I've seen cheaper but not with any quality.I would agree with Smitty about running out near or even outside the rails and also flanging it for access later(even if it costs a bit more the first time you use it you will save that and the $371)
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-13-2007, 08:28 PM   #5
streetstar
streetstar's Avatar
Sounds pretty good -- prices for stuff in GA is probably comparable to what we pay in Okie land --
i paid about 300 for a similar set-up, (regular 40's tho, not Super 40's) only mine dumped in front of the back tires, (like a Ford Lightning)
streetstar is offline   Reply With Quote
Old 06-14-2007, 09:26 AM   #6
rophle1
rophle1's Avatar
Thanks for the reply's, especially the tip about running them wide for the tank. I do plan on the relocation of the tank and wasn't even think about them being in the way. I would've been p*ssed in a couple of months when I had to move them.
They will be welded.
Thanks.
Ronnie
1968 C10 Stepside
396 bored .030
TH400
