Old 06-13-2007, 08:54 AM   #1
RyanG
RyanG's Avatar
How do I remove Universal Joints?
Just as the title says. I don't know how to remove the universal joint from the drive shaft. I removed the cap that goes on the differential and now I don't know how to remove the joint from the drive shaft side. Can anyone help? Thanks
RyanG is offline   Reply With Quote
Old 06-13-2007, 09:09 AM   #2
grayw0lf
Re: How do I remove Universal Joints?
There are some C shaped retaining clips that must be removed.
Then press the caps out. You can get a special oversize C clamp at many of your local parts stores.
What kind of truck? Some later models have nylon injected into the caps that can make removal difficult. In that case, your propane torch si your friend.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-13-2007, 09:12 AM   #3
bigjimzlll
bigjimzlll's Avatar
If it has retainer clips...remove them. I use a vice and some sockets. Place a socket big enuff that the cup of the U joint will fit in on one side of the U joint. Then use a smaller socket that will fit inside of the loop of the other side. Place in the vice(or C clamp) and squeeze. The smaller socket will slide the whole U joint to one side pushing out the cup.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-13-2007, 09:20 AM   #4
RyanG
RyanG's Avatar
Cool..Thanks guys...will I need to compress the new one to get it in also? Oh BTW I have a 71 1/2 ton p/u.
Old 06-13-2007, 10:04 AM   #5
jhow66
jhow66's Avatar
If you have never done this before I would take your shaft to someone that does and watch. Then you will be able to do the rest yourself without screwing them up.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-13-2007, 10:16 AM   #6
onetonk5
Cereal Killer
onetonk5's Avatar
I agree with letting someone who knows how to do it....watch and learn. I used to use the vise/socket way but after busting a vise in half I learned ho to do it with a small ball peen hammer. You need to be careful not to damage the ends of the cups while driving them back in. I watched a buddy at a local driveline shop who uses a hammer and learned from him. Its not rocket science but it is important to get it right. I would think you could get it done for less than a secong u-joint would cost if you mess the first one up.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 06-13-2007, 10:37 AM   #7
cdowns
cdowns's Avatar
when assembling you have to be extremely carefull that the needle bearings stay in place /grease helps with that// personally i'm old and lazy now and just spend the extra to have a shop do it and have the shaft checked for balance issues
Old 06-13-2007, 11:03 AM   #8
shifty
Questionable
shifty's Avatar
I typically use a BFH and a large socket (3/4 or larger usually works). Pull the retaining clip out, lay the square end of the socket up to the U-joint and beat the hell out of it. It'll come out.
Installation is pretty much the reverse of removal: insert one end into the yoke, slide it into place, beat it into place from the first end you inserted. like cdowns said, DO NOT remove the caps and if you do, be sure they all line up and stand up perfectly when the cap is put back on. Remember to grease them up afterwards!!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-13-2007, 11:17 AM   #9
RyanG
RyanG's Avatar
Thanks for all the wisdom and knowledge guys. It got me worried for a second so I did some researcha and found this, http://dodgeram.org/tech/repair/U_joint/repair.htm
Now I feel much better about doing it.
Old 06-13-2007, 03:28 PM   #10
shifty
Questionable
shifty's Avatar
that's a great idea for pressing them in. i always just beat them back in. no harm, no foul.
Old 06-13-2007, 03:52 PM   #11
oteixeira
I use this, I figure for the cost, If it pays for itself in U-joints I don't beat the life out of before I use them.
http://www.harborfreight.com/cpi/cta...emnumber=38335
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 06-13-2007, 04:01 PM   #12
casterbuster
Mejor Que Nada
casterbuster's Avatar
One at a time...sorry j/k
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 06-13-2007, 11:41 PM   #13
eedgell
It's the air up here
eedgell's Avatar
heat from a torch is not needed unless it has those damn poured in plastic retainers! Replaced all of mine on the tail gate of my truck with a hammer and large drift puntch. Not hard to do.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-14-2007, 01:08 AM   #14
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i use a BFH and a big bolt held in place by a pair of vise grips.
I suppose a Clamp or a vise might be easier, but this way i get to take my frustrations on the poor little U joint. Just did a set this weekend actually. And i feel calm and relaxed now
IvelDesigns is offline   Reply With Quote
Old 06-14-2007, 01:24 AM   #15
IvelDesigns
this looks pretty cheap and easy to use too:
http://www.harborfreight.com/cpi/cta...emnumber=46694
Old 06-14-2007, 08:44 AM   #16
grayw0lf
Orlando
I Hate HF with a passion. They sell 95% garbage. But these are actually pretty decent & the exact same ones you'll see elsewhere, like at CarQuest for well over $100.
05' Dodge Neon
94' Seadoo SP
Old 06-14-2007, 09:58 AM   #17
oteixeira
grayw0lf,
I hate HF too, but with this, the price difference was huge, and I took into account the number of moving parts. I will not buy anything from HF that has a motor, or even anything that needs a bearing (because they will use cheap bushings). When I looked at this though I thought to myself "how can they f* up a C clamp with a special hole in it??" and I was right, they can't, at least, not yet. I have had it for over a year and it still works fine.
Orlando
Old 06-14-2007, 10:30 AM   #18
truckdude239
truckdude239's Avatar
i got one of there floor jacks had 2 years now no problems
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-16-2007, 08:54 PM   #19
msgross
msgross's Avatar
remove the clips, place in vise with one small socket on one end and a larger than cap socket on the other..... now turn the big handle and you're set....
If that fails then the BFH method works with sockets as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
