Old 06-13-2007, 05:33 PM   #1
sb69chevy
sb69chevy's Avatar
PS Pressure hose revisited
Was working on putting on the new pressure hose, but the one I got to fit requires a male adapter on the pump. Because of this, the metal part of the hose hits on the motor mount and I can't seem to get it started. If I could find a hose w/ the male fitting on both sides, I don't think I'd have this problem. Also, anyone have a pic of how your hoses are routed? Sorry if this has been posted before and I missed it. Thanks in advance.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 06-14-2007, 07:40 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: PS Pressure hose revisited
I noticed the same thing with my '70. Not for sure what year the donor was for the pump, got from a picknpull. THe old hose has the male tube-nut on both ends. The 4X4 steering hose (in the parts store pic) has the male on both ends, but not sure if it would fit the truck, not tried it yet. If nothing else, get the right male tube-nut, cut the line, and reflare it(putting the nut on first). Thats my plan if the 4X4 hose won't fit.
Good luck.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 06-14-2007, 08:28 PM   #3
sb69chevy
sb69chevy's Avatar
Well, finally got it in today. Had to bend the metal portion a bit forward and toward the ds fender. After I got it started onto the adapter, it was easy. I'm not sure if the routing of the hose is correct, but it works nonetheless...finally. I seriously considered cutting and reflaring just as you said, just didn't have the flaring tool. Let me know how it goes.
Old 06-14-2007, 08:39 PM   #4
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
a medium/heavy duty truck shop should be able to make one up for you , some around here will do it . what about a napa can they make hoses?
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 06-28-2007, 06:46 PM   #5
jgrh64
jgrh64's Avatar
Don't know if you got it on but I went through it today , bought my hose from autozone online and what I found was the new one wasn't bent exactly same as old one so I just carfully tweaked it so they matched up. I put the box side on first but not tight and then wrestled with the pump side- it fit running the same as original but JUST fit with allot of Sunday school words like H#$% and Da%^ and oh Jesus!
Old 06-28-2007, 08:27 PM   #6
70C10Toejam
Hellasick
Nice to hear it worked for ya.
Could not find anyone around here that builds PS hoses. Almost built my own from AN fittings from a local speed shop, had some metric/o-ring to AN adapters. But then found the Lee inserts.
STill trying to get a crank pully, thought I found someone with one, but was a long water pump.
