Hi everyone...
I'm working on a '72 Chevy C20. I have tried multiple searches on this but I can't find an answer... My headlights, front running lights, side markers and flashers all work on my truck. But my turn signals do not. I haven't wired in the rear lights yet but that shouldn't be an issue, I should be able to get something out of the front blinkers. They should be lit up solid at least if only the front ones work, but there's nothing there. Hazards work just fine though. I took the column apart and cleaned all contacts in the turn signal switch. Not sure if there is an inline fuse somewhere or a fusible link. It only has one flasher "can" in the fuse block, unless there's supposed to be another one somewhere... Any ideas would be helpful... Thanks, Scott
1972 C10 1972 C20 ![]() |
Re: Need some help with my turn signals...
wire up the rear lights and see
its all about the +6 inches
there is supposed to be two flashers in the fuse box.
71 rustless in texas
Two flashers, if your emergency flashers work, your missing the turn signal flasher. Move it over to the other spot and try again.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" ![]() 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
Yep, you guys were right. I didn't notice but there are two spots for flashers. My Haynes manual only showed one in the wiring diagram, so I thought one worked for all of them. It works perfectly. I just have to get a turn signal arm somewhere now...
