06-13-2007, 10:38 PM | #1 |
King of Rust
Anyone run just rear bags?
What kind of setup would just rears require? What size tank, compressor etc.. I'm clueless when it comes to bags (I know a c-notch is needed). Thanks.
06-13-2007, 11:31 PM | #2 |
Re: Anyone run just rear bags?
I ran 2 2600# Firestones w/some schrader valves for almost 2yrs before I upgraded to a compressor, small airtank, & dual gauge/manual controller. I set the air pressure & left them alone.
The only reason I upgraded was I started towing my trailer more frequently & was adjusting the ride height more often. Items required are: 2 Firestones (or equivalent), 1/4" DOT airline, & 2 schrader valves for a cheap manual fill system; or.... that + 1 Thomas (or equivalent) small air comp, 2-gal airtank, controller for a manual fill system; or.... all of that plus solenoids/valves for an automated system.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-13-2007 at 11:36 PM. |
06-13-2007, 11:47 PM | #3 |
King of Rust
Thanks for the info,,, I guess I should have stated I'm trying to make a tail dragger, so it needs to be a automated system so I can adjust the height on the fly.
Like this! Last edited by KAILUAZ; 06-14-2007 at 01:25 AM. |
06-13-2007, 11:54 PM | #4 |
c notch kit
4 valves 1 gage for tank 2 switches 2 bags 1 3 gallon tank 1 small compressor air line (3/8" for bags - 1/4" for gage) various fittings a few cases of beer a weekend |
