06-13-2007, 11:26 PM | #1 |
senior member
need some electrical help
For some reason I dont seem to be able to open the valves on my airride setup. I ahve power going to my switches, I have good grounds, I used 14 ga wire to wire the valves (was this too small?) Im really hoping its due to the fact that my battery was low at the time that I did this. battery is now on the charger If anyone has any ideas Id really appreciate it.
Jason
69 GMC bagged Last edited by pissonNOS; 06-14-2007 at 12:46 AM. |
06-14-2007, 01:35 AM | #2 |
Re: need some electrical help
check all the wires to the valves and make sure theyre all good and not burnt or anything and check all other connections cause maybe something got shorted out somewhere, thats all i cant think of right now
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-14-2007, 04:48 PM | #3 |
I think u need air pressure to operate the valves
06-14-2007, 05:41 PM | #4 |
The LuvShack Garage
Keeping an eye on this one, hope to wire mine up at the Board meet
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-14-2007, 08:13 PM | #5 |
he is correct. you need pressure to open as well as to keep them closed.
but you should be able to barely hear the solenoid "click" a little once power is applied regardless of whether the system is pressurized or not. |
06-15-2007, 12:24 AM | #6 |
Mine had a rather loud click when switched. The best thing to do is listen, but if all else fails, run a speaker wire to the valve straight from the battery.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
06-15-2007, 08:24 PM | #7 |
senior member
got this figured out now apparently where it says ground you dont put the ground there makes sense hey haha. anyways got them working now
69 GMC bagged |
