Quick ground strap question
There are two ground straps for my "71" GMC pickup. I did not take the one off that resides in the engine compartment so I am not positive where it goes. My first thought would be on the back side of the heads, but there are no holes located there. (diff heads)
Can someone tell me where the ground strap that is connected to the firewall should connect to? The only other place that seems realistic is a header bolt. That is unless it should not have been on the firewall in the first place. Does anyone know where the original location of the engine compartment groun strap should be located? Thank You, Valentini |
Designated A-hole!
Re: Quick ground strap question
If you look on the back of the block (between head and bellhousing) on either side there is a hole that the spark plug wire loom is mounted to on mine, that's where I connect my ground straps, one to either side. If you don't have anything bolted there you need a 1/4" bolt at most 1/2" long.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
![]() Join Date: Aug 2006
Mine was located under a valve cover bolt.
proper place is one strap to each valve cover
I will check the block again. In the meantime I did place it on the valve cover bolt. Thanks for your replies.
Valentini |
Designated A-hole!
That may be, but it looks a heck of a lot better hidden behind the engine.
#7 | |
yes i agree but i answered the question he asked
mine is bolted to the tranny bellhousing, 1 on each side.
