Old 06-14-2007, 01:27 PM   #1
55dude
55dude's Avatar
t-5 in a 61'
dudes anyone here put a t-5 in a 61'? the truck currently has a 235/3spd and was wondering what was invoved in putting in a t-5 to make it more driveable. i'm not worried about if trans will hold up to heavy loads because it only hauls an occasional motor. thanks.
55dude is offline   Reply With Quote
Old 06-14-2007, 02:46 PM   #2
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Re: t-5 in a 61'
I put one in my '62. It's a bolt in deal as far as the tranny goes. You do have to cut about half of the pilot shaft off and also shorten the driveline and fit it with a slipyoke. One from a TH350 will work. It is a really nice swap though!
Imperial Kustom is offline   Reply With Quote
Old 06-14-2007, 03:17 PM   #3
slepysal
slepysal's Avatar
Re: t-5 in a 61'
How about a how to?
slepysal is offline   Reply With Quote
Old 06-19-2007, 11:51 AM   #4
55dude
55dude's Avatar
Re: t-5 in a 61'
any pic's of the new crossmember and driveline? thanks
Old 06-19-2007, 11:07 PM   #5
53lowdown
Junior Member
53lowdown's Avatar
Re: t-5 in a 61'
I hear that a Richmond / Doug Nash 5-speed is the easiest bolt in, because the pilot shaft works and it bolts right up to the stock belhousing so you can use your existing clutch. Might have to change the driveshaft - but other than that it's supposted to be a bolt in. Anyone know for sure?
There's one on Ebay currently at $1200 - Item number: 270133010705
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 06-20-2007, 03:37 AM   #6
PrerunnerRob
PrerunnerRob's Avatar
Re: t-5 in a 61'
I have researced this, and be sure to check out shifter placemennt. If I remeber what i read before you can get a t5 world class tranny, and use a s shifter set up to work.
PrerunnerRob is offline   Reply With Quote
Old 06-20-2007, 01:23 PM   #7
55dude
55dude's Avatar
Re: t-5 in a 61'
if you check out the t-5 page the nwc and wc differences are not shifter location it's the internals. all the s-10 t-5's have shifter in same location,nwc or wc. camaro and mustang t-5's have shifters in different locations than s-10 t-5's.
Old 06-20-2007, 08:51 PM   #8
PrerunnerRob
Re: t-5 in a 61'
Sorry about that, I should have been more clear. The s10 shifter position is more ideal for a truck instead of the car location. I did see somewhere online where a guy too a world class camaro tranny and used the so shifter setup so it would fit in his truck better.
