USMC
body/tub support how to?? replacing floor,rockers.........
I finished separating the frame and body. I have all the sheet metal I need to replace the floor rocker boxes inner outer rockers pillars etc. What have you done to support the font half of the body while replacing all this?? My frame and axels are going out to be stripped sealed and painted. and it seems much easier to work the body while its up and off the frame. I am going to put the top on it and line it up and move the bracing inside so i can put the doors on for alignment when needed. I have plenty of HD steel saw horses that i can cut and change the size of as i need. I don't know were to support it so that its secure and also going to keep the body as straight and level as possible. thanks for any of your ideas and help.
here are some pics of what im working with now. BTW its not on those jack stands now that was only temporary its fully supported by saw horses.
Semper Fi |
The LuvShack Garage
Re: body/tub support how to?? replacing floor,rockers.........
Don't shoot the messenger, I am sure there are ways to do it off the
frame like your is now, but I was always told to do it while the frame was still under it and with the top on to keep everything squared up.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
USMC
I'm not looking to argue or "shoot the messenger" at all!!
I had that feeling that maybe it should be on the frame. At the same time, if the top and doors are on wont that show if its aligned? I dont know. my frame should be less than a week out. I have never done this much body work ever. hell I have never had anything off the frame before so this is all new and I will take all advice and info that i can get.
Semper Fi |
The LuvShack Garage
![]() 2004. Like I said there are ways to do it as it sits now. I am just not very familiar with how to do / have not actually done it either. Craig
The LuvShack Garage
Again, just what I hear here, doors and tailgate keep it square during tub
removal. Braces can be made using measurements found in threads here. If it has a full cage that will help keep it square, assuming it was square in the beginning when that was 1st installed. An assembly manual has alot of good measurements in it and may be very handy in these types of builds.
If you could wait till your frame comes back, I think you would end up with a better final product. I had mine supported with a pipe that went across my work shop and hung the cowl from that, there is a fender bolt hole in the rite location and you still have access to the hinge bolts, BUT I had a frame under it.
A wise man said to do one side at a time, and that worked for me. The door is the key, since you want it to open and close when your dun. It would be a nice time to put new body mounts under it... I'm sure you can find lots to do until your frame comes back. I'm sure I left things out but others will give you advice as well. Sit back, read and enjoy the ride. It is what it is or what you make of it. JMHO J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Did you get that in Utah??? I've never seen that much rust personally (in person just picts from back east). I live about 3-4 hours south of you, want to by my nice rust free AZ K5? Kinda joking but wow, I'd say if it is off of the frame already, it's too late to put it back together, just use the saw horses on the body mounts and make the doors open and close then brace it up and cut!! Good luck!
#9 | |
Can't wait to retire!!
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Simple? What's simple?
![]() Join Date: Apr 2007
When I had my Typhoon done (first project, didn't tackle the sheet metal on that) the shop I had doing it absolutely refused to touch it without a chassis under it. So I would say that is the way to do it.
Although, I am getting a little crazier with my projects these days ![]()
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
Oh, man. Looks like fun to me, been researching this for months. Keeep up with the good pic's!
#12 | |
USMC
I'm going to definitely wait until its back on the frame with the fresh body mounts and bolts to mess with the sheet metal. I'm going to run new fuel and brake lines as soon as its stripped primed sealed and painted. this adds a couple weeks to the build !!!DAMN!!! lol Ill have to pull it back off the frame to properly seal up the bottom. If you have a tub for sale let me know. Ill take a front half with or with out a firewall.
Semper Fi |
