Old 06-14-2007, 03:05 PM   #1
truckster
truckster's Avatar
Ball Joints on 4X4 - how involved?
OK, I know I could have posted this on the Blazer page or on the 4X4 page, but I figured more people hang out here so I might get a quicker response. I'm kind of in a hurry because I'm taking the boys to Scout camp next week and I wanted to take the Blazer.
I've got a 72 Blazer K5 I just got running. I took it to get inspected and emission tested and everything was good except the ball joints. They'll be happy to do them for around $500, but I can get the parts for $90. I have a 20 ton press and ball joints are nothing new to me, but the 4X4 is. So what do I need to do to get to the ball joints? The front axle is (I believe) a corporate 10 bolt, at least there's 10 bolts on the cover.
Thanks for your help.
truckster is offline   Reply With Quote
Old 06-14-2007, 03:35 PM   #2
keenee
Re: Ball Joints on 4X4 - how involved?
I did this some years ago, not too tough, hardest parts were pulling the spindles and the steering arm has three tapered bushings that were tough to remove.
'96 GMC Suburban 6.5t
'99 F**d Windstar
'07 SON
'09 DAUGHTER
XOXOXO Wife
keenee is offline   Reply With Quote
Old 06-14-2007, 03:45 PM   #3
Rust Buster
Rust Buster's Avatar
Just did this yesterday.
Getting the steering arm off was the hardest for me.
Then getting the balljoints out was hard but I did that to myself. I was pushing them the wrong way. They both come out the top.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 06-14-2007, 03:46 PM   #4
truckster
truckster's Avatar
What do I need to do to pull the spindle? I imagine I have to take the hub (it's a manual locking type) and then I'll find the spindle nut. Anything special I should know about in there?
Old 06-14-2007, 03:52 PM   #5
Rust Buster
I don't think you have to. I did mine in conjuction with a total build of the truck so I am taking everything off. It definitely made things easier
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 06-14-2007, 03:53 PM   #6
RED72blazer
urban fourwheelin
RED72blazer's Avatar
you just need the special hub socket.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-14-2007, 04:53 PM   #7
Rust Buster
That will make it easier, or if you are lucky, you can back it off with a screwdriver and a hammer, not saying that's the right way though
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 06-14-2007, 04:59 PM   #8
ckhd
ckhd's Avatar
Your front axle is a Dana 44.
If you have a press, there's not too much to changing the ball joints. I didn't even have to take off the steering arm on mine (the '72 'burb). The special tools are the spindle nut socket (a big sucker with four teats) and a socket to take the sleeve out where the ball joints go (a little sucker with four teats). I rented a ball-joint press to do mine, already had the spindle nut socket, and bought the sleeve socket.
Get a manual, if you don't already have one. There are torque specs and procedures that you need to follow if you want it to be right.
While you have it apart, make sure you grease the inside of the spindle (where the front axle shafts pass), grease the u-joint on the axle shafts (replace if needed), check the needle bearings inside the spindle (and grease them), and replace the seal inside the spindle (not just the one in the hub). It's a lot easier to do it while you have it apart already than to have to take it apart again later to fix it.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
