Old 06-14-2007, 04:33 PM   #1
itsmike2k
DOT air hose PSI?
I have been looking at some catalogs and most DOT approved fittings and hose are only rated to 150psi. Do people run different hoses for 200 psi systems or?? I know you can buy fittings and Nylon hose rated for more but i just have seen people talking about DOT approved hose and thought i would ask..
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 06-14-2007, 08:11 PM   #2
Shane
Shane's Avatar
Re: DOT air hose PSI?
Most DOT components are tested and rated at a safety factor of 2 ... in other words, take the maximum pressure they recommend and multiply it by 2.
You should be fine up to 200 psi.
Shane is offline   Reply With Quote
Old 06-18-2007, 01:38 AM   #3
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
why do you need 200psi? most setups only require 30-40lbs up front, and 60-70lbs out back.
IvelDesigns is offline   Reply With Quote
Old 06-18-2007, 10:24 AM   #4
itsmike2k
Most compressors are either 150 or 200psi, so the fittings and hoses to and from the tank need to be able to take that psi..
Mike
