06-14-2007, 11:05 PM | #1 |
torsion bar air bag susp?
Has anyone done or does anyone know of a bagged torsion bar front suspension drop?
06-15-2007, 12:00 AM | #2 |
Re: torsion bar air bag susp?
You want to keep the bars and run bags with them, or convert to a coil front end and run bags?
06-15-2007, 06:30 AM | #3 |
Gotta keep the bars due to 4wd. I've seen something on blazinlow.com that airbagit.com is supposed to have (porkchop) but couldn't find it on their site. I've not heard a lot of good things about AIM so it may be a blessing in disguise.
06-17-2007, 01:15 PM | #4 |
Interesting. That's the first I've seen of it. One thing to keep in mind is that the bags will add compression "length" to the existing torsion bars. It will be like running a taller spring if it were coil. Make sense? So I would imagine that you would want to run heavy bags so that they are there for height adjustment only and let the torsion bars act as the springs.
06-17-2007, 02:09 PM | #5 |
I also thought about hydros to adjust the height and still let the bars do their job. Another solution I found included welding bags to the top a-arm and fabbing an upper mount. That upper arm and ball joint weren't designed to bear the weight of the truck so I'm tossing that one. I think I like the other idea using a coilover. In this case use a shockwave or maybe extend a shockwave and fab/relocate the upper mount. It may require a tubular upper a-arm. I'll probably do this and a mild Z on the frame to keep the ball joint angle in a good range.
06-17-2007, 02:29 PM | #6 |
is the truck 4wd?
If not you can yank the bars and use torsion bar air bag brackets...do it all the time on nissans and toyotas |
06-17-2007, 02:36 PM | #7 |
Yep. 4wd has to stay. I've never done a 4 wheel burnout but I think it's going to be REAL fun.
