06-15-2007, 02:10 AM | #1 |
WIW.......intake?
I have a GM cast iron high rise off of a 68-396 and was wondering if was worth much of anything........Thanks Jason
72 Cheyenne Super 80 Silverado Blazer 2wd |
06-15-2007, 04:31 AM | #2 |
Re: WIW.......intake?
in my experience, there's not much demand for the spreadbore manifolds, especially with the aftermarket aluminum intakes being so cheap.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
06-15-2007, 07:32 AM | #3 |
I agree, I used to only pitch the small block ones, but lately I haven't been able to give away the big blocks ones either. Some guys may want it for the casting number and/or date if they're doing an original restoration, but if it's in your way, I say pitch it.
70 Custom/10, 396, Muncie 4spd, SWB SOLD 72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver 72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne |
06-15-2007, 07:40 AM | #4 |
Senoir Member
What's the casting numbers? That may make a difference. If it's checked and found to be crack free.....around $75. Shipping will be around $50 due to the weight. The BB manifolds are bad to crack between the large holes of the carb, the crack will run down into the intake and usually causes problems with the idle. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
06-15-2007, 05:33 PM | #5 |
its all about the +6 inches
run the casting numbers, if it is off a desirable muscle car, it may be worth something... if it's just a stationwagon motor or truck motor... it's probably worth it's weight in scrap.
06-15-2007, 06:18 PM | #6 |
Not much unless you have the motor, heads, etc, etc. I just sold a 375 hp 396 and did well because it was all date coded within a month.
06-15-2007, 07:31 PM | #7 |
Thanks for the input. I think I will use it on my 402 even thought it won't be 100% correct. The 402 needs all the help it can get.
I was checking the value because I know where I can get another one but he wants $200. which seemed too high to me.
06-16-2007, 12:59 AM | #8 |
The "Mark of Excellence"
