06-15-2007, 07:35 AM | #1 |
flywheels and starters
okay i built m,y 305 out of an 78-79c-10 i have the flywheel out of the same truck i had it turned at school is the teeth the same as the 71 307? i just trying to figure out if i need a different starter the the ornigal one
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-15-2007, 09:43 AM | #2 |
Re: flywheels and starters
Use the starter off the engine you rebuilt and you should be good to go.
If you don't have that starter, check the mounting hole bolt pattern between the rebuilt block and the starter. If the bolt pattern is the same, it should work.
trailers are for boats |
06-15-2007, 07:52 PM | #3 |
i dont have the starter off the 305 as far as mounting hole they are on the bellhouseing i am need to know about the number of teeth
06-15-2007, 07:53 PM | #4 |
just answer my own quest the 71 and 78 use the same starter
06-17-2007, 08:36 AM | #5 |
If you are talking about an automatic trans There are two types of starters and two sizes of flexplates that apply during those years, 14" 168 tooth plate uses the starter that has the staggered bolt pattern and the 11.5" plate 153 tooth uses the starter with the side by side bolt pattern. Hope this helps you out?
