Old 06-15-2007, 11:28 AM   #1
uncle
Instrument Cluster ?
I have a truck that the cluster lights never woked in ( Didn't bother me cause I never drive it at night), but now I want to fix it. All gauges and other lights worked until last week. The temp gauge stopped working. After changing all senders,gauge w/one I know is good and printed circuits,ect., I still cannot get the temp gauge or the lights on the l/h side of the cluster to work. Any suggestions.
uncle is offline   Reply With Quote
Old 06-15-2007, 11:32 AM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Instrument Cluster ?
What kind of condition is the cirsuit board in? this can make a difference. sometimes they get wet and nasty and corrode causing bad connections.
jkaylor68gmc is offline   Reply With Quote
Old 06-15-2007, 11:36 AM   #3
uncle
I've changed the p/c and even put a cluster from another truck that is running and all gauges and lights working but no luck. Could it be one wire in the harness where it plugs to the back of the cluster?
Old 06-15-2007, 01:42 PM   #4
RyanG
RyanG's Avatar
You may want to get a meter and start checking for a short in the wires that goe to the instrument cluster.
RyanG is offline   Reply With Quote
Old 06-15-2007, 02:06 PM   #5
jkaylor68gmc
yeah.
Old 06-15-2007, 02:55 PM   #6
shifty
Questionable
shifty's Avatar
meanwhile, if you want some replacement stock gauges, let me know, i've got several leftover from my cluster rebuild. next time i'm out, i'll drop em off, or, if you'd rather, i might want to swap for a part of some sort.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
