06-15-2007, 01:25 PM | #1 |
Sofa King. We, Todd, Ed.
Hydro Boost Opinions?
It seems my brake booster on my 71 Blazer has failed. I could easily replace it and the master cylinder for around $120. OR I could go hydro boost (used) for I'm guessing a little more than twice that. My question is: Do you guys really think its worth the $$ and effort? I'd love to hear all the pros & cons. Thanks!!!
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
06-15-2007, 03:15 PM | #2 | |
Re: Hydro Boost Opinions?
Mike
Mike Redpath |
06-15-2007, 03:41 PM | #3 |
What does this mod do? And what year 1/2 ton donar truck should I look for? I have a 72 blazer btw.
06-15-2007, 03:48 PM | #4 | |
Will you be going to a hydro assist at some point? I believe it's possible to do both but it'd be interesting to install for sure. How about using a one ton booster for now and doing rear disc's later? Works for me pretty well. |
06-15-2007, 04:42 PM | #5 | |
I never planned on putting on rear discs, is that the only option if I go with a hydroboost brake system? Maybe I dont understand hydro boost. Doesnt it essentially mean that the power steering pump helps the brake booster or do I have that back ward?
06-15-2007, 05:25 PM | #6 |
The hydroboost replaces the booster you currently have. The hydroboost runs on steering pump pressure rather than mechanical vaccum pressure. A properly functioning hydroboost will not adversely affect steering but you will be able to see a difference if you are not use to a hydroboost. I don;t even notice the difference any more except my 97 1 ton crew will stop quickly if need be. If you go junk yard hunting, most 1/2 ton hydroboost setups were is 6.2 diesel trucks.
Mike
Mike Redpath Last edited by Musclerodz; 06-15-2007 at 05:25 PM. |
06-15-2007, 06:32 PM | #7 | |
Sorry if I wasn't clear. Like the above post states, it runs both from one pump. I was asking if you ever plan to run a hydro assist or even full hydro steering set up, that's where I'm unsure if their compatable. (will work together from one pump) The one ton booster w/rear disc's is only one other option to running a hydro boost braking system. Clear as mud now? |
06-16-2007, 10:00 AM | #8 |
Post Whore
I really like the hydroboost setup I put on my 69 K20 - of course I was going from manual brakes so the improvement was big for me. Sure stops my 35"s easily. Here is a linkto info on my install.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-16-2007, 05:11 PM | #9 |
The last few hydro set ups on ebay off 6.2 and 6.5 diesels have sold for 150 or less so it shouldnt cost that much more then going to the 3/4 or 1 ton booster and master. And a tip on buying the booster and master dont buy the complete unit. When I went 1ton on my blazer it was 160 for the master and booster together I priced them by them selves and it came out less then 100. I didn think it was worth the 60 to have them bolt it together.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 06-16-2007 at 05:12 PM. |
06-16-2007, 10:41 PM | #10 |
I put Hydroboost in my C30 duallie(see avatar). I can lock up the front tires in a panic stop at 60 mph. While carrying a Blazer.
I am putting hydroboost in everything I own.
Just as if I knew what I was doin' |
06-19-2007, 01:26 PM | #11 |
Thanks everyone for you input and expertise. I think I'm gonna just replace the stock booster for now, feeling lazy .
VT: I dont think I'm ever gonna go with hyrdro-assist steering, BUT then, I never thought I'd go one-ton either... Do you think I'll need that after I go w/crossover steering? I've managed along with stock steering this long...barely.
06-19-2007, 06:57 PM | #12 | |
When I was running 37's my stock pump would get hot and just lock up. No real power to turn the bigger tires even when it was working but maybe I had a sucky pump, dunno. |
06-19-2007, 11:39 PM | #13 | |
My stock pump has been thru hell w/o the crossover steering, it might spit a little fluid now and then but still works. Sure, it doesnt have the power to turn the wheels at all when I stick the front in a rut...just makes things more interesting.
06-21-2007, 06:46 AM | #14 |
Sounds like you got a 'super' pump.
J/K - My pump never work for sh!t, that's the reason I changed it. To help out your stock pump, consider installing a remote cooler. |
