Old 06-15-2007, 06:44 PM   #1
bullwinkle
New Member
71 GMC control arm interchange
While changing ball joints I found that my lower control arm is worn. The nut on the control arm shaft fits loose and no longer threads into the control arm.
I assume 71 and 72 are the same because of the disk brakes, but do any other years interchange?
This is RH side on a 71 GMC 1/2 ton 2wd.
I probably should have posted this under suspension. Maybe a mod could move it. Thanks.
bullwinkle is offline   Reply With Quote
Old 06-15-2007, 10:36 PM   #2
uncle
Re: 71 GMC control arm interchange
67-72 should work as long as it's a 1/2 ton. The ball joints will be different, but a/arm should be the same.
uncle is offline   Reply With Quote
Old 06-15-2007, 10:55 PM   #3
bullwinkle
New Member
What about anything newer? There aren't many 67-72's in wreckers around here. Lots of 73 and up.
Old 06-15-2007, 11:14 PM   #4
68chevy68
68chevy68's Avatar
The 73 and ups have different shaft bushings. Not sure if they mount to the xmember the same or not though.
68chevy68 is offline   Reply With Quote
