drive it till it dies
spark plugs
whats the best brand of spark plugs for a 80' model 350?
Re: spark plugs
i like Autolite 25 or NGK plugs. Stay away from platinum plugs in older motors
Re: spark plugs
thanks man, anyone else got anything
Re: spark plugs
I use AC Delco myself. What GM uses!
Re: spark plugs
i've been using ac delcos but i had an accident taking my headers out tonight. i figured, hell its time to change them anyway.
Re: spark plugs
AC Delco - if it's good enough for the GM factory, then it's good enough for me.
![]() Join Date: Sep 2005
Re: spark plugs
ac delco i nevert have trusted neverlite plugs (autolite)
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
sufficiently talented fool
![]() Join Date: Jun 2006
Re: spark plugs
use AC Delco plugs in a GM. Autolite plugs in everything else. Use Champion plugs ONLY if you can't get anything else, and it has a mower deck under it.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
GEARHEAD
Re: spark plugs
This is just IMO but I use AC Delco plugs most of the time. Autolites have treated me very well in all my race applications also. Even better than AC Delco
I would not tell my worst enemy to run a champion in his lawnmower ![]() JUST MY OPINION THOUGH RJ22... ![]() |
Re: spark plugs
Just curious cooters, why not the Platinum plugs? I've been saving pennies to spend $8-$12 a plug, I have headers & I don't want to change them very often, so I thought I'd get the spendy ones.
#12 | |
Re: spark plugs
I'm currently trying to get a newly-swapped-in 350 to start, and during the swap process, I put in some Bosch Platinums (and stupidly threw the old nasty ones away). Now it won't start. With a screwdriver in the plug wire laying near a ground, the HEI will throw a 3/8" spark. With a plug sitting on a ground, it SOMETIMES makes a spark, but even then it seems weak. Either way, I've been through everything else, and I'm pretty sure it's the plugs giving me grief. Now I have to wait for the munchkin to wake up from her nap so I can run to the store... Anybody know WHY platinum plugs don't work?
"Grampa's Truck" - 71 K20 - 350/465/205 It's been in my family longer than I have... |
#13 |
Re: spark plugs
bosch dont work because they have no exposed electrode so when any carbon or fuel gets on the plug they misfire. Platinum plugs have a tiny electrode and also tend to misfire when oil, fuel or carbon get onto the plug. Platinum plugs work well in motors that run really clean with higher cylinder temps. These are my findings anyway.
#14 |
Re: spark plugs
Makes sense, thanks cooters
#15 |
Re: spark plugs
I wasn't thinking correctly, I meant I was saving up for those spendy Irridium plugs, any reason to go with them? Not go with them? Is it gonna be the same problem as with the Platinum
#16 |
Re: spark plugs
i havent tried those plugs but i believe it is not worth the money when an ac/delco or autolite works perfect. American testing has proven NO power gains with fancy plugs which is why you wont see adds promoting more power anymore.
#17 |
Parts and more parts
Re: spark plugs
Use AC Delco, but if you need header space, then I have been running the plugs from Accel. I have been using them for years and they have not failed me yet.
#18 |
New Member
ac delcos r45ts,imo best plug out there!I have been usin them all my life.
#19 | |
River life......
Re: spark plugs
X2
#20 |
![]() Join Date: Jul 2006
Re: spark plugs
AC or NGK. I've heard Autolites are good but now you're talking about using a ford plug right? Champion is for a lawn mower.
