Transmission-bell housing question
Recently I broke the Bell housing/ flywheel cover. I would like to replace the part but I don't know the size of my transmission. How do I figure this out OR how do I replace the old part without knowing the transmission size?
History-I just bought a 1968 c10 short bed. When the kid sold it to me he said it had a 283 engine, and that's about all I know. (I’m not even sure that is correct.) As you can tell I'm a little green at this but I do plan to learn my way around and get this truck rebuilt. I appreciate any help on the bell housing questions for now.....thanks |
I am a Referee of life.
Re: Transmission-bell housing question
You came to the right place for info.The 68 will have a bellhousing thatbolts to the frame on either side.IIRC all of them are the same.If you subscribe to the BB there are classifieds where you can look.I'm sure someone has a bellhousing that will fit.
BTW WELCOME to the besyt resource you will find for info on these trucks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jul 2004
Be sure to check the size of the bearing retainer hole at the back of the bell, IIRC 67 and earlier was smaller and 68 up had the larger hole, someone here will remember the dimensions. Check the for sale thread, threre were two for sale on the same thread a few days ago, from the pics it kind of looked like one ws small hole and the other large hole.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Join Date: Feb 2002
'67 trucks with both 3-speed Saginaw and 4-speed SM420 used a bellhousing with a 4-9/16" diameter pilot bearing hole [GM p/n:3815891]. '68 [and later] 4-speed trucks used a bellhousing with a 5-1/8" opening [GM p/n:3925505].
Is it a 3-speed (shifter on column) or a 4-on-the floor? If it's a 4-on-the-floor, is Reverse to left [toward you] or right [away from you]? If to the left it's a 420, if to the right it's a 465. The bell housing is the heavy cast iron part on top. The flywheel cover is the sheetmetal guard on the bottom. Don't lose it, they're hard to get now. Did both break?
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-17-2007 at 06:39 AM. |
#5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Awesom, thank you. It's a 3 speed on the column. The only part I broke was the bell housing--it was plastic.
its all about the +6 inches
can you provide a photo of what you broke? I'm thinking we have termanologymixed up here.
#8 | |
Does the post-'68 Saginaw have the larger 5-1/8" diameter?
#9 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 06-18-2007 at 10:20 AM. |
#10 | |
