06-16-2007, 11:26 AM | #1 |
Chief Honcho In Charge
Found in the driveway
I am guessing it is form my truck.
72 SWB, K10 Fleetside...not that much of that matters. Is this something off my front suspension? I crawled underneath and saw nothing obviously missing or disconnected. I am sure as soon as someone tells me what it is and where it goes...bang it will be very obvious. Is there a nut I am missing? DO I reinsert this one or by a new one?
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
06-16-2007, 11:28 AM | #2 |
Re: Found in the driveway
I think it's a shock mount.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-16-2007, 11:42 AM | #3 |
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
06-16-2007, 12:44 PM | #4 |
upper shock mount
06-16-2007, 12:48 PM | #5 |
Are any shocks loose or missing from the truck?
06-16-2007, 12:50 PM | #6 |
rear upper shock mount I would bet...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-16-2007, 01:44 PM | #7 |
urban fourwheelin
definatly an upper shock mount...just replace them last week on a buddies truck, when we did shocks.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
06-16-2007, 03:02 PM | #8 |
I thought that as well.
I spent 30 min looking again. Cannot find anything...I am starting to believe it may not be off my truck...but could have landed on my driveway and bounced into my driveway form someone driving by. I am going to add another photo...this one has a quarter to show size reference. It does look like a shock mount bolt...until you see the size of it. My front end looks good...old but good. My springs are all help in place...my shocks have all their bolts. Any more ideas? Tim
06-16-2007, 03:05 PM | #9 |
Out of the carpool lane.
My first thought was that it was part of the ball joint until I read some of the responses. I dunno.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
06-16-2007, 03:09 PM | #10 |
check you xcase shifter bolt, maybe someone replaced it with that??
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
06-16-2007, 03:13 PM | #11 |
Post Whore
Yep, that is my bet too!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-16-2007, 03:23 PM | #12 |
Wow , I would have guessed track bar mount at the axle if it was 2wd....
06-16-2007, 03:27 PM | #13 |
The oddest Todd around
Well... it could be worse. I once found a brake pad in my driveway upon returning home from work...... and it was from my car. Tore that caliper all the hell up. It did explain why it was pulling when I hit the brakes though. LOL
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
06-16-2007, 04:34 PM | #14 | |
It sure seems huge for that.
06-16-2007, 08:20 PM | #15 |
72 chevy
I would say one of your trany adapter bolts out of the 2 that hold it to the cross member.
Ed |
06-16-2007, 08:28 PM | #16 |
Is it a bolt or a sheared off stud? Almost looks like its got a hex allen head on it...
06-16-2007, 08:42 PM | #17 |
River life......
I would check the tcase shifter.
06-16-2007, 09:57 PM | #18 |
It is a bolt...with a smooth shoulder section and a threaded area. It is a hex head bolt...and of course the washer...I am not even sure it is off my truck.
I was under my truck again...and still cannot find where it may go. There are two bolts that hold the trasnfer case in fron the bottom...bot are there...and they are not hex head. I cannot fins about bolt like it. I even looked at the cab mounts..no go..all are in place.. Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) Last edited by timcos; 06-16-2007 at 09:59 PM. |
06-16-2007, 10:00 PM | #19 |
When you say transcase shifter...do you mean the rod that comes through the floor in my truck through the rubber boot? Hence the shifter?
It is secure and shifts properly.
06-16-2007, 10:07 PM | #20 |
And of course by the reference to the quarter...you can see this thing is big.
06-16-2007, 10:35 PM | #21 |
I dont know about 4x4 stuff much so I cant help with any transfer case stuff but from the looks of the bolt the head sits flush when installed. It looks a lot like a brake caliper bolt but the washer kills that idea & they are usually a lot longer too. No help from my end I guess...
Did you check your riding lawnmower for missing parts? Something off the deck maybe? No clue... Last edited by corn; 06-16-2007 at 10:37 PM. |
06-16-2007, 10:40 PM | #22 |
guess you'll know sooner or later if it's important!
06-16-2007, 11:13 PM | #23 |
72 chevy
Did you check the two bolts for the transfer case support bracket on the frame.
Ed |
06-17-2007, 01:52 AM | #24 |
After 25 years of taking these trucks apart and reassembling them. That does not look familiar at all.
06-17-2007, 02:32 AM | #25 |
Neighborhood Pickle Slinger
I think someone just threw it in your driveway just to get you worried.
Here is a closeup of the upper shock mount. Looks almost the same but mine has a hex head and the thing you have is round.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
