ok with open carrier how to determine ratio the cheater way, by jacking a wheel and turning tire, i suppose if was 2,73 ratio then driveshaft turns 2.73 times to one rev of a tire ? or ? jst making sure, i need to find out whats in the 82 T/A, is supposed to be 2.73 from factory, just want to confirm its that or not. may swap the 3.73 rear out of the firebird to under it if needed..
hmm.... thanks ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
i blocked one tire and put car in neutral and spun tire one revolution exactly and the driveshaft spun 1 turn and then about 2/3 or 3/4 turn, this trick never works for me, im telling you its not fool proof. that says its anywhere form 3.23 to 3.73, thats impossible unless someone has been in the axle, these cars had 2.73, 2.93, 3.08, 3.23, 3.27, 3.42 and 3.73 ratios avaialable, so this is no fun.,
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited April 29, 2002).] |
I think you have to spin both rear tires equally.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
tried that, does same thing
do it this way: make a mark on the tire thats off the ground (leave the other side down if it's a peg leg). Turn the driveshaft until the mark on the tire makes one complete revolution. Count the # of times the driveshaft has turned while the tire turned exactly one revolution. If the shaft turned 3 1/4 times, then you have a 3.23:1 ratio. A little over 4 turns, 4.10 etc... Easier to do with two people.
steve moore |
You did everything close to correct. Jack one side of rear end up, tranny in neutral. Turn free tire 2 complete revolutions. If drive shaft turns less than 3 full turns, it is 3.0:1 (2.73, etc.) or less. Barely more than 3 turns = 3.07. Close to but not a full 4 turns = 3.73 or 3.90. No, this isn't an exact science, but gets pretty close without opening the rearend up.
------------------ '72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72) '70 Olds 442 convertible '70 Olds Rallye 350 '72 Olds Cutlass convertible [This message has been edited by Yellow Cheyenne (edited April 29, 2002).]
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72) '56 Chevy short step V-8 (My dad bought it new!!) '70 Olds 442 convertible '70 Olds Rallye 350 |
ok, here is the correct way to do this. do exactly what you did, jack up one wheel and turn it TWO full turns this will give you the correct ratio. or multiply the 1 and whatever that you got by two. the most accurate way is to turn the wheel 2 times.
sorry yellow didn't see yours, you are correct. Nathan ------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A [This message has been edited by texnician01 (edited April 29, 2002).]
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran ![]() Nathan & Tiffany |
