Old 06-16-2007, 05:53 PM   #1
superman3405
Junior Member
superman3405's Avatar
A/c
Guys, i put a new compressor on the truck last weekened to get it cooled off inside. The problem is it is not cooling, just blowing. Any suggestions on what I should trouble shoot?
Don
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 06-16-2007, 06:12 PM   #2
1970shortbed
Active Member
Re: A/c
im sure u rechaged the system with new freon after the new parts but its a thought because i forgot once lol
1970shortbed is offline   Reply With Quote
Old 06-16-2007, 06:19 PM   #3
Blue4x4
Blue4x4's Avatar
Re: A/c
Did you do a leak check with nitrogen and pull a vacuum to 300 microns?
Blue4x4 is offline   Reply With Quote
Old 06-16-2007, 09:31 PM   #4
superman3405
Junior Member
Re: A/c
yeah new freon, and no leaks....
350/350TH
Old 06-16-2007, 09:49 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: A/c
So is the compressor clutch engaging?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 06-16-2007, 09:56 PM   #6
clay68c10
clay68c10's Avatar
Re: A/c
Recirc flaps closing? Is it even a little bit cool? What kind of pressures are you seeing?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-17-2007, 10:34 AM   #7
1970shortbed
Active Member
Re: A/c
yesterday in my truck it seemed to just blow and i wiggled the switch back and forth and bingo it was working good again
i think it was just stuck in the middle as i was just playing wit hthe switches a few minutes prior
Old 06-17-2007, 11:19 AM   #8
Blue4x4
Blue4x4's Avatar
Re: A/c
glad to hear it's working again.
Old 06-20-2007, 11:29 PM   #9
Andy4639
Old member
Andy4639's Avatar
Re: A/c
Check the push button on the back side of the vent at the center of the floor board it's got to hit the switch when you have the A/C on. The cable may not be adjusted just right.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
