72 Cheyenne
Looking for this alt bracket
for a SBC, see the the pic, it's about 17 inches measured along the top edge. mine is broken and held together with a hose clamp. anyone have one? The pic is too large to upload here but here's the link
http://new.photos.yahoo.com/aikidoji...804427263193/0 |
![]() Join Date: Mar 2003
Re: Looking for this alt bracket
bad link on the pic
72 Cheyenne
should work now
go fast, cheap, and easy with this one. either junk yard it, or cut one out yourself.
If you're not in to big of hurry, I'm pretty sure I have a couple. I'm 600+ miles from home right now though.
I can look when I get home. Should be this coming weekend. Keep reminding me though. I have a terrible memory...
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Why don't you just have it welded up, at say a muffler shop or something
River life......
I agree with the welding, that is how I fixed mine.
#8 | |
Bloo
if you still want one, i have one id take $20 shipped for.
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
72 Cheyenne
PM sent.
72 Cheyenne
I've had it welded three times already, keeps breaking. I've looked around for another one but been having a hard time find the exact one, most won't fit.
Always on the hunt...
dion - I have permanently fixed this same problem you are having by doubling up back to back alt. brackets and adding longer bolts. Try getting two identical type upper brackets or even use your repaired one along with another if you find a match for it. Good luck on your fix, C.B.
I dont know if you know this there are 2 versions of the upper bracket. There is a 69-71 version and a 72 only version. The 72 version is longer than the 69-71 version. I think they did that because of the redesigned alternator case in 72. Just thought I should add this info. The 69-71 is easy to find but the 72 one ishard to find.
| Bookmarks |
