Old 06-17-2007, 10:26 PM   #1
wyatt earp
motor mount question
was finally able to work on the '72 this weekend,got the 6cyl. out, changed flys andother stuff. was told that i would have to move the org. motor mounts forward 1 hole on the frame rail. when i did that the top holes were fine but there is no coresponding hole in the cross member for the botom of the mount. do i need adifferent mount or do i need to drill a new hole?
wyatt earp is offline   Reply With Quote
Old 06-17-2007, 10:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: motor mount question
to do that, you'll need the small block style mounts.
you can leave the towers in the old location, it'll just put the engine close to the wall. Won't need to replace driveshaft or linkages this way either.
Old 06-17-2007, 11:12 PM   #3
Chevelle454
Chevelle454's Avatar
I had to do this a couple weeks ago on a friend's truck. I6 towers work in their original location with V8 mounts. But, the V8 will be very close to the firewall with minimal clearance for the distributor.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-17-2007, 11:17 PM   #4
brak
brak's Avatar
my motor was mounted in the I6 location, and worked fine...
couple weeks ago i installed the correct motor mounts, moving the motor forward, and I lucked out... my truck had a TH-350 with the short tailshaft, and i installed a 700r4, and it just so happened, that the amount th motor moved forward was exactly the same as the difference in length between the two tranny's, so my driveshaft mounted up without any modification
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-19-2007, 08:47 PM   #5
wyatt earp
i was told that i would have to make some slight modifications( with a big hammer) to get the distributor to not hit the wall, if i left the mounts in the I6 location. also i'm using the 3spd man. trans. thats already in the truck. do i have to move the trany forward also, if i move the towers forward? thanks.
Old 06-19-2007, 10:19 PM   #6
71tahoe
71tahoe's Avatar
That's good to know!
I disagree with the hammer. I have done this to 2 trucks. A 71 and a 69 and they both had enough clearance for the HEI. You can't leave the cap on when installing but it does clear with plenty of room. You will need a short, slim screwdriver to fasten the cap because it's so close but no interference.
71tahoe is offline   Reply With Quote
Old 06-20-2007, 01:22 AM   #7
guf
i just went through this yesterday. i have a donor truck done the correct way , and receiving one is a 350 on the 6 cylinder tower mounts. i was wondering why there was so much room in one and not the other. i would recommend getting the correct mounts for the front holes. although plenty of people seem to have it done the otherway with no problems.
guf is offline   Reply With Quote
Old 06-20-2007, 01:50 AM   #8
68shortfleet
So what is the correct holes for each factory motor configuration? REar holes for I6? Front holes for SB and BB? I got my truck as a dissamebled 68 that was originally a SB/3spd truck. It will become a SB/700r4. What holes to use?
Jason
68shortfleet is offline   Reply With Quote
Old 06-20-2007, 12:10 PM   #9
Chevelle454
Hook the trans up to the engine, align the trans on the trans crossmember mount, and see where the front mounts need to be. We wanted to use the V8 mounts but with the factory 4 spd that was behind the I6 we had to use the rear engine mounts with I6 towers becasue of where the trans sat...
1972 C10
1972 C20
