Old 06-18-2007, 01:48 AM   #1
jackyl9999
jackyl9999's Avatar
Tips for sound deadner install.
Hey everyone. Ive got some ultimate b-quiet (100sq ft.) I was wanting to get some tips from anyone that has installed this stuff, Pics of a install, where to put it, that kind of stuff. Thanks for all the help! this board is great!!!
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 06-18-2007, 08:08 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Tips for sound deadner install.
I installed a product called "Brown Bread".
Here is the post about that.
http://67-72chevytrucks.com/vboard/s...ht=brown+bread
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-18-2007, 10:35 AM   #3
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
I used fatmat - good stuff great price.
Here is the link:
http://www.carconnectionsd.com/blaze...eriorpics.html
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 06-18-2007, 11:07 AM   #4
Shane
Shane's Avatar
I used FatMat as well.
My only advice is to NOT try to do too big of an area at one time. I covered everything from under the rear window/rear wall, all of the floor, up the firewall, and under the dash. Purchased a 100 sq./ft roll and had PLENTY left over for the doors. If the mat appears to be too stiff, apply a small amount of heat with a hair dryer or a heat gun ... DOESN'T TAKE MUCH.
Always use a sharp blade ... I went thru approx. 10-12 utility knife blades.
Good luck and post some pics once your done.
Shane is offline   Reply With Quote
Old 06-18-2007, 12:16 PM   #5
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
I used Second Skin Damplifier from just below the rear window, up to just under front cowl on the firewall.
I put 2 layers on the firewall and then put a layer of their Overkill over the Damplifier.
Although my truck is far from being finished it made a huge difference in the way a bare cab sounds if you tap on a metal surface.
Hope this helps...
Sandemonium is offline   Reply With Quote
