Saving 1 truck at a time!
Door Weather Stripping
I have heard that the Chevy S10 door weather stripping is both thinner and it clips on the body seam making it much easier to install/use. Anyone have experience with this? What year S10?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Re: Door Weather Stripping
Found the thread...'82-'93 S10 or Blazer.
Fabricate till you "puke"
I have s 10 weatherstrip on my 69, but the doors do shut firmly. I had to use a hammer & dolly to knock the pinchweld in somewhat to get the doors to close. It goes on slick tho.....just clip it on, no glue/no mess. On a stock set , you will come up a tad short of the opening & need to splice the bottom center. I had to shorten mine 6-8" to fit the 4" chop top.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Questionable
the stuff i bought from GMC Paul's was snap-in and came from like ... 78-93 dodge truck or something. Great fit.
i'd suggest buying it. better fit than the garbage S10 seals i found at the junkyard. just my 2¢
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Location: vacaville ca, because it as far from indy as i can be
i used the stuff from my 77, was a little thick but the doors still shut. exactly the right length. but it does not have the angle cut for the top front corner of the jamb. still fits nicen tight and cant tell its different.
