W T B Turbo 350 Adapters
I Need The Adapters To Remove A 4 Speed And Install A Turbo 350 Up To A Np205 Transfer Case? My Trans Man Said I Would Need A Short Shaft.adapter And Plate? Can Anyone Help?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
Re: W T B Turbo 350 Adapters
i believe the input on the 205 has a different spline for a 350 than a 4 speed. I know a turbo 400 adapter uses a larger bearing requiring a larger bearing hole in the 205
72 chevy
![]() Join Date: Jan 2007
You will need a 27 spline transfer case input shaft, slev and adapter. The 4 speed has a 10 spline input shaft in the transfer case.Probably be cheaper to find someone to trade.
Ed |
| Bookmarks |
