Old 06-18-2007, 07:39 PM   #1
missilekounty
When my battery gets just about dead
my starter trys turning the truck over if the key is just in the on position. Why?
missilekounty is offline   Reply With Quote
Old 06-18-2007, 09:45 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: When my battery gets just about dead
Sounds like you have a ground problem. Double check the ground connections, and make sure that you don't have oil all over the starter and solenoid...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-19-2007, 01:25 AM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
when the voltage gets really low a solenoid will stick into a position and either not swicth or jam into position and have a hard time releasing.
my dump trailer with a isolated battery and 12v hydro pump will not change from up to down if the battery is dead enough.
trkklr77 is offline   Reply With Quote
