Old 06-18-2007, 08:20 PM   #1
68K20
Noobie McNoobster
68K20's Avatar
Master to Prop valve lines
Anyone know what size the lines are supposed to be that go between the master cylinder and proportioning valve? Truck in question is a 1968 with 1972 brakes. Here is what I have now, the drum side seems to be bigger than the disk side.
Here is a pic of what I have now.
The Stable:
1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes
1990 Chevy V2500 Suburban
2005 Kawi KLR650
1983 Honda Goldwing GL1100 Standard (Naked)
1995 Miata M
Fortes Fortuna adiuvat
68K20 is offline   Reply With Quote
Old 06-19-2007, 09:08 AM   #2
Americanrider
Re: Master to Prop valve lines
Thats the way they are, drums need high volume/low pressure (large size lines) and the disk side needs low volume/high pressure (small lines)
Americanrider is offline   Reply With Quote
Old 06-19-2007, 02:14 PM   #3
68K20
Noobie McNoobster
68K20's Avatar
Thanks, that was what I thinking, I am getting ready to rebuild all the brakes in the truck (Master Cyl, WHeel Cyl, Calipers, soft line and etc) and just wanted to see if I should look at replacing the hard lines as well.
The Stable:
2005 Kawi KLR650
1995 Miata M
Old 06-19-2007, 02:23 PM   #4
Orange
Licensed to Thrill!
Orange's Avatar
Just a question - I knew this before doing my setup - but went ahead with the all 3/16" line to the prop valve anyhow.
Is this going to matter?
My line to the prop valve is longer than most...(from there on it is 1/4" just like normal). My prop valve is on the frame, so I have a little more line there. I don't know if it is going to hurt anything, but just wondering if anyone might know for sure.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
