Old 06-19-2007, 03:01 AM   #1
63chevyfleet
63chevyfleet's Avatar
reving problems some one help
i have have a 230 in my truck and i start it up to run it after it is warmed up then i got to gas it fast it starts to back fire like it sounds like to much gas is in the carburator or something so i am wondering if it could be the distributor set or timing on the distributor is off well if any one knows that would be great thanks
63chevyfleet is offline   Reply With Quote
Old 06-19-2007, 03:31 AM   #2
raiden7800
Straight "6" Shooter
raiden7800's Avatar
Re: reving problems some one help
I would like to know as well... I have the same problem.. but I have a 292... single barrel rochester.
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 06-19-2007, 03:56 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
check the floats in the carbs, they could be fuel logged (like water logged) and sinking and trying to flood out the engine, my truck did that and thats what fixed it
if thats not the case then try advancing the timming a bit and see what happens
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-19-2007, 04:09 AM   #4
raiden7800
raiden7800's Avatar
I have already reset my floats... didnt really make any diff... and I spent a whole day (and a tank of gas) messing with my timing, and it made no difference either( though now I have a really cool small backfire at an idle, and when slowing down in gear ). In my situation, I have a rebuilt single barrel rochester. I have no idea how good the workmanship is on it, and I am led to believe that the workmanship of the carb itself may be to blame.
On an original carburetor, I know that the bar holding the throttle linkage, and the butterfly valves round out their journal after X amount of years, and allow air to get inside, causing a vacuum leak, and subsequently, a backfire or "miss" situation.
If yours is the original carb, or just an old one, try closing the choke plate a little bit a ta time, and see if that helps.. if it does, then I would gestimate to say, that the Air/fuel mixture is out of whack, and/or the carb is just worn out, and needs a rebuild/replacement.
Old 06-19-2007, 04:23 AM   #5
GREASEMONKEY72
reseting the float level isnt going to help on a fuel logged float because its still going to sink
if its backfiring while slowing down it sounds like its running rich, it does sound cool and i love it to
-steven
Alte Seele S.S.
Old 06-19-2007, 09:16 AM   #6
LAFNATU
LAFNATU's Avatar
Sounds to me like the timming chain jumped a tooth or two, you mignt want to take off the timming cover just to make sure... Just my two cents...
LAFNATU is offline   Reply With Quote
Old 06-19-2007, 09:28 AM   #7
hewlett2002000
hewlett2002000's Avatar
dont mean to hijack the post but i have a similar problem. i know two possible causes. when i hit the gas sometimes it stalls out, but not enough to die most of the time. but it is kind of embarrassing to pull up at a light and let off the clutch and hit the gas and it stall and die. i know its running rich but im not too good at carb adjustments. also the little plate that has the notches to set the timing is broke off so the timing may be off. i set it the best i could by ear though. i have a mild 350 with a edlebrock performer and holly 600cfm 4bbl. again sorry to hijack but any suggestions would be great.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-19-2007, 11:28 AM   #8
setandreel
setandreel's Avatar
Been chasing that demon for 3 months, It was my exhaust heat riser stuck half open and a small exhaust leak at the manifold. Took exhaust and intake apart cut out riser installed new gaskets and run like new Hope this helps.
Mike
setandreel is offline   Reply With Quote
Old 06-19-2007, 07:22 PM   #9
raiden7800
raiden7800's Avatar
292 cant jump a chain tooth..it doesnt have a chain. Gear to gear action there.
Old 06-20-2007, 03:51 AM   #10
PrerunnerRob
PrerunnerRob's Avatar
Ok, this might sound a little off but...a few years ago, I had a 2 stroke quad, and I can feel the eyebrows raising now, but check your fuel lines for cracks. My quad had a fuel line crack, and every time I hit the throttle, the line would suck in air and stall out until it came back to idle... it took me weeks of adjusting the jetting, messing with the carb adjustments, only to find it was drawing in air instead fuel every tiem I laid hard on the throttle. I do realize there is a pump to pressurize the line between the carb and the pump, but check it, it might be an easy fix.
Also, check to see if your pump is overriding a sticky float, I have had a few cars that have done it to me!
PrerunnerRob is offline   Reply With Quote
Old 06-20-2007, 04:16 AM   #11
hewlett2002000
well my fuel line is junk on my truck so that could very well be. it is soon to get eaither a fuel cell in the bed or a tank under the bed so im changing the lines then.. depends on what i find at the swap meet this weekend.
thanks,
John
Respect:
