Old 06-19-2007, 11:51 AM   #1
rauto13
saving one more
rauto13's Avatar
Greasable Trailing Arm bushings?
I am getting ready to install new polyurethane trailing arm bushings in my 69 short fleet. It seems that I have read somewhere about making these bushings greasable. Since I have heard that poly bushings have a tendency to squeak, should I make them greasable? And if so, how can I do this?
Any help would be appreciated.
EIDT*** I decided that the above might be a bit confusing, I can and will grease the bushings before assembly, what I am wanting to do is to install grease zerks in the outside bushing housings so that I can grease the bushings later.
Is this necessary?
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 06-19-2007, 12:28 PM   #2
cdowns
cdowns's Avatar
Re: Greasable Trailing Arm bushings?
putting grease fittings in the housings wont do a thing as the bushings dont move in the housing the only movement is the center hole of the bushing around the bolt// just use the silicone grease they give you with the bushings and grease the bolts real well// you should clean the bolts real good before assy by either wirebrushing or blasting
Old 06-19-2007, 12:30 PM   #3
larry may
x2
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 06-19-2007, 07:34 PM   #4
rauto13
saving one more
rauto13's Avatar
Thanks for the help, I bought new grade 8 bolts, so bolts and bushings are new.
Just wanted to make sure I wasn't gonna have squeaks.
